Please advise if there is a work around. If not, Adobe really should fix this issue.
As you've noticed, Muse will clobber any changes made to the pages Muse works with that have been done outside Muse*. Are the page title features provided not enough for your purposes? Does the information in this thread help at all: Re: How do I add Meta tags to pages?
* Excepting changes made through 'In-Browser Editing'.
Rob, you can go into site settings and untick the option so Muse will first read page changes made. I do not use Muse so I do not know the exact setting wording. But it will be in there.
I've gone through the settings in Muse CC, found nothing but the normal 'In-Browser Editing' sync feature.
Even manually running 'File › Sync with Web Version' didn't pick up meta tag changes I'd made in BC.
There's nothing I could find in the help files, or on the web, about a sync feature any better than the IBE sync.
I would be astounded if Muse could merge even moderately complex changes made outside IBE.
The setting is in BC under settings isn't it?
But it is Muse,
Not really the thing to use to build actual websites
