I have been spending hours trying to resolve this problem. I have uninstalled & installed the Flash Player numerous times without success. Currently, Adobe website says I do not even have the Flash Player installed even though I received the box telling me that it has been installed successfully. I have followed several discussion threads trying to resolve this on my own.
HELP!
I am using a MacBook Pro, OS X version 10.9.4 running Safari 7.0.6. I am trying to install the latest version on the Flash Player.
Yes, I close Safari each time I have tried to download. Yes, Java Script is enabled.
Hello kouponkim,
Does the installer fail with an error or does it complete successfully? If it fails with an error, please post a screenshot.
Flash Player files are installed to the /Library/Internet Plug-ins directory. Do you see 'Flash Player.plugin' in that directory?
Maria
It completes successfully or so it says. I get through all 3 steps.
No I do not see it in that file folder. Yes, I know how to find the library/Internet Plug-ins file (it is hidden in version 10.9.4 but I know how to find it).
Sorry for delay in responding. This is still very important to me to get this fixed. I manage a website that utilizes flash player.
Kim
Hi. I am still unable to use the latest Flash Player.
Kim
Hi Kim,
If you're not seeing 'Flash Player.plugin' in the /Library/Internet Plug-ins directory then it is not installed. The browsers know to find Flash Player in that directory.
Please provide screenshots of the installation completion screen (How to post a screenshot in the forum).
Thank you.
Maria
This is what I get every time I installed the plug in.
The Flash Player is not in /Library/Internet Plug-ins directory. How do I get it in there?
Please try downloading and running this installer:
If that doesn't work, can you please post the install logs?
Where do I find the Flash Player installation log on the Macintosh?
See screen shots. Said it installed it but still not there.
Hi Kim,
There are no screenshots posted. Along with posting the screenshot, please provide the following install log files:
Both log files will be fairly large. Instead of posting them in you're reply, you can follow the instructions here to upload them, How to share a document.
Maria
Before I go through the process of signing up with Adobe ID. I don’t know where to look for those 2 logs.
I searched Finder. install.log did return a few but the dates are years old. Snd FlashPlayerinstallManager.log returned nothing.
Kim
You already have an Adobe ID. It's what you're using to log into the forums.
You can use the Console app to view the log files. Open Console (in /Applications/Utilities). A list of log files will appear on the left and the content on the right. Search through the list for the files, FlashPlayerInstallManager.log will be in ~/Library/Logs and install.log will be in /var/log, then right-click on the file and select "Reveal in Finder". If you don't have right-click enabled in your mouse, you can select the file, then on the main Console menu select File > Reveal in Finder.
There should be a current versions of these files. Flash Player creates/writes to FlashPlayerInstallManager.log every time Flash Player is installed or uninstalled and install.log file is a system file that is written to every time an application is installed.
Maria
Are you running any AntiVirus/AntiMalware software that may accidentally be preventing the installation?
No I am not.
