Show 1 reply
1. Re: Use the presenter on local PC
Jorma@RealEyes Aug 27, 2014 8:50 AM (in response to adob1948)The short version of the answer is that the font used in the PPTX deck is probably not one of the fonts available to the MS Server (which Connect lives on and is doing the conversion of your PPTX deck to Flash on), so it has to substitute it out for another similar font, thus causing the formatting issues. If you publish it locally, then you are using the fonts available on your computer to convert it to Flash, and have no formatting issue as a result.
So, you can either switch to a font that is in the standard MS list (I'm sure with some digging we can find a reference to that list), or publish locally with Presenter before pushing it up to Connect.
