I've imported my FM8 book into RH10, and the map IDs are created beautifully (thanks Jeff!). So now I want to give the files to the developer to test the new calls. The .h and .ali files are in the project folder, I don't see them in the SSL/Webhelp folders. Do I include them separately, or are they converted to some other file name/type in the output folders?
Laurie
I manually copy my .h file into the output folder for the programmers to use – adding it as a baggage file didn’t seem to make any difference.
Thanks Jeff. Do they need the .ali file as well? I'll also send them the CSH API folder in the flavour they specify. Is there anything else they'll need other than the output folder and .h file?
In my case, no, they only use the .h file to build a cross-ref table in the software to launch the CSH. YMMV depending on what method is used.
Great, thanks again.
LL
