5 Replies Latest reply: Aug 29, 2014 12:01 AM by rixter123 RSS
    Extension callback issue
    AYS. HAKKIM Community Member
      Hi All
      I just got the problem with (html + javascript + jsx) html5 extension. Actually callback works; the control comes back to the javascript from jsx. But its not getting the value returned from jsx. But the same works out perfect in indesign; javascript callback gets the value returned from jsx.
      can any one please suggest immediate!
        • 1. Re: Extension callback issue
          rixter123 Community Member
          What is the type of the return (a string, etc)? It's hard to guess the cause without seeing any code.
          • 2. Re: Extension callback issue
            just string! even i tried by returning as an object. all those ways are working perfect in InDesign (jsx to javascript). even in "after effects" i can get control back to callback function. the only issue is, it is not getting the returned value.
            • 3. Re: Extension callback issue
              Would be able to have a look if you could post a bare-minimum code snippet, both JSX and Javascript. Returning strings to the callback function works for me.
              • 4. Re: Re: Extension callback issue
                Here the code;
                HTML
                <!doctype html>
                <html>
                    <head>
                        <meta charset="utf-8">
                            <script src="./ext.js"></script>
                            <script src="./lib/CSInterface-4.0.0.js"></script>
                            <link rel="stylesheet" type="text/css" href="./style.css">
                    </head>
                    <body onLoad="onLoaded()">
                        <button id="popAlert" onClick="onClickButton('AEFT')">Pop An Alert</button>
                    </body>
                </html>
                javascript
                function onClickButton(ppid) {
                  var extScript = "$._ext_"+ppid+".popAlert()";
                  evalScript(extScript, function(a){alert(a);});
                jsx
                $._ext_AEFT = {
                    popAlert : function()
                        alert("hi im in After Effects!");
                        return "hi. im in javascript callback!";
                "Returning strings to the callback function works for me."  on After Effects?? I'm using AFX CC 2014, version 13.0.0.214.
                • 5. Re: Extension callback issue
                  Sorry, I was checking with Photoshop. My bad for not noticing you are asking about After Effects.
