I was trying to follow these instructions, and have 3 .cer files that we use for our
Exchange server.
I'm trying to install the certificates, I got 1 installed, but when I try the others, I'm getting:
Certificate not imported, (mkey) already exists.........
But I'm still not able to access the Exchange server.....getting a error that says:
Could not login to the Exchange server. | |
Verify the server name, username, and password. Ensure that proper client certificates are installed. |
You might have to merge these certificates in a single file. They're just text files, you should be able to do this in Notepad. If I recall correctly, you may need to specify them in the same order as their hierarchy: root, intermediate, specific.
Dave Watts, CTO, Fig Leaf Software
http://www.figleaf.com/
http://training.figleaf.com/
Fig Leaf Software is a Veteran-Owned Small Business (VOSB) on
GSA Schedule, and provides the highest caliber vendor-authorized
instruction at our training centers, online, or onsite.
Read this before you post:
http://forums.adobe.com/thread/607238
This is a 'me too' post.
I'm having the same kind of problem described in the original post.
I got cfexchangeconnection working between ColdFusion 10 on my PC and the exchange 2010 server. This involved importing the server's certificate & etc.
When the working code was transferred to a server running ColdFusion 9, (and yes I did remember to also import the certificate to the server )
I find that the connection no longer works. I get:
Unable to connect to the Exchange server using HTTP/HTTPS protocol. | |
HTTP response code : 302 | |
Just to get that far, I had to remove the serverversion attribute which was added with CF10 and not supported in CF9
I also tried changing the parameters thusly:(changes in Bold)
<cfexchangeconnection
action="open"
username="#config.username#"
password="#config.pwd#"
connection="mailpickupconn"
server="mail.mydomain.com"
mailboxname="My Account"
protocol="https"
formBasedAuthentication="true"
formBasedAuthenticationURL="https://mail.mydomain.com/owa/auth/owaauth.dll" />
The attributes in BOLD were added from a recommendation I found on another forum, but to no avail....
Is there a cfexchangeconnection solution for the combination of CF9 / Exchange 2010 (&& 2013) / HTTPS ?
TIA and Cheers,
