1. Re: Why does Premiere Pro CS3 no longer import .psd files?
Ann Bens Sep 4, 2014 2:14 PM (in response to SVLbyler)Make sure the psd is set to RGB and not CMYK.
And as a side note: Get all your project assets of off the C-drive and put it on a separate 2nd internal drive.
2. Re: Why does Premiere Pro CS3 no longer import .psd files?
SVLbyler Sep 4, 2014 4:44 PM (in response to Ann Bens)Thank you for your answer. I'm glad someone is listening.
This is not a new mask; I have used it successfully for years. Only recently did PPro CS3 stop accepting it. My workaround was to save it as a .jpg. If PPro ever stops accepting .jpgs, we're all in big trouble.
But to answer your question: The .psd is, and always has been, in the RGB color space.
I work on a laptop, so there is no separate internal drive. The project file, stills, titles, and masks are all on the internal drive, but the video material is on two external HDDs (one for each of my cameras.)
3. Re: Why does Premiere Pro CS3 no longer import .psd files?
Ann Bens Sep 5, 2014 4:17 AM (in response to SVLbyler)If Premiere is acting weird, restart computer.
Hold down shift+alt while opening Premiere.
Then empty all media cache.
jpeg do not have transparancy. You can save as png instead.
4. Re: Why does Premiere Pro CS3 no longer import .psd files?
SVLbyler Sep 5, 2014 12:07 PM (in response to Ann Bens)I couldn't imagine what any of those steps would do for my problem – but I didn't have a better idea so I tried them:
It's a laptop, so it was off all night. I turned it on this morning.
If I hold down shift-alt before clicking the desktop icon, all it does is select all icons from top left to the Premiere icon. It does not start Premiere.
If I press and hold shift-alt immediately after clicking the icon, Premiere displays every tiny module it loads rather than summarizing. I held shift-alt until Premiere was fully up and idle.
I did that. As I write, Premiere is busy reconstituting all of that.
Then finally, the acid test: Try to import a .psd file. Bzz-z-zt! Still claims it's an unknown file type.
> jpegs do not have transparency. You can save as png instead.
I'm using it as a track matte key, so white is equivalent to transparent. I do have to select "matte luma" instead of "matte alpha" in the effect. I'll save your advice in case I ever do need transparency.
Follow-up: I checked my other licensed copy. It accepts .psds just fine. I checked Help About for both; they're identical: 3.2.0 (374). So the problem must be in an internal setting, an external influence, or a defective module. And remember, it's not just me, Björn in Germany reported the identical problem in June.
