1. Re: Insert frame hold segment bugs
Ann Bens Aug 28, 2014 4:22 AM (in response to eikonoklastes)If Premiere is acting weird restart computer and hold down shift + alt while opening Premiere until welcom screen.
This resets resp. Plugin cache and preferences.
See if that will work.
2. Re: Insert frame hold segment bugs
eikonoklastes Aug 29, 2014 11:16 PM (in response to Ann Bens)Hello Ann. Thank you for your reply.
Instead of resetting my preferences I decided to check on a fresh install of Premiere Pro on another machine.
I tested on a Windows 8.1 machine this time using the same version of Premiere Pro CC - 2014.0.1, 8.0.1 (21) Build.
This time the problem with the Cross Dissolve did not occur. I'll try resetting my preferences on the other machine and report back tomorrow.
However, the problem with the incorrect duplicate frame markers did repeat, so this definitely seems like a bug. If you have Premiere running, please try to replicate this - it only takes a few seconds.
Thank you.
3. Re: Insert frame hold segment bugs
Ann Bens Aug 30, 2014 3:47 AM (in response to eikonoklastes)Yes I can reproduce the duplicated frames.
Set up an Insert Frame Hold Segment on the timeline.
Then right click on this segment and open Frame Hold Option; its set to Hold on Time. Hence the repeated frames.
