Hi Robert
The other files will vary, depending on your choices when you
published. In a nutshell, I'll list them here.
Files you commonly see
* MainMovie.SWF (Contains the main part of your movie)
* MainMovie_skin.SWF (Contains the playback controls and
other information - You may banish this file and force the controls
into the MainMovie.SWF by clicking Project > Skin... >
Borders tab and DE-selecting the "Show Borders" check box.
* MainMovie.HTM (This is the HTML file used to present the
movie to your user. Contains sizing information and also looks for
the fourth file, standard.js)
* standard.js (Contains code used by the HTML file)
Files you may see if different selections are used:
MainMovie_fs.HTM (Created when you select the Full Screen
option. If this file exists, you point your user to it instead of
the MainMovie.HTM. When launched, it contains a link that opens the
movie in a browser without toolbars and such)
MainMovie.ZIP (If you use the .ZIP files option, this is the
only file you will find.
autorun.inf (If you use the autorun option, this file is
created for you to burn to the CD to autostart it in a PC)
Hopefully this helps... Rick
