I am on windows8.1. I have installed Adobe Flash Player. It says it's installed and shows on control panel programs. When I try to play anything that requires Flash Player, I get a message that says it needs to be installed.
Enable the Add-In. Tools, Manage Add-ons, click on Shockwave Flash Object and click enable (bottom right of window), close, try the website that was giving you the error.
UPDATE: just saw that you use FF, not sure of where to manage add-ons but try enabling Shockwave in FF.
On what browser?
Firefox
Dido !
Have Slimbrowser
Yo dnard nother ? , got need name of certificate on gsn games where r the certificates ?
did it and stilldon't work !
For Slimbrowser, disable the In-page ad filter
is it the same as ad blocker ?
yes that's it. if that doesn't do it reset all settings. what website is giving you the error?
IT WORKED ! Playing games on G S N free games and always got flash player need though knew I had it , Thanks VERY much for UR advice .
you're welcome. what fix did you apply? disable ad blocker or reset all settings
both but disable ad blocker didn't work but reset all settings did , thanks again
Thank you so much. It's fixed!
I followed these instructions that you sent. Enable the Add-In. Tools, Manage Add-ons, click on Shockwave Flash Object and click enable (bottom right of window), close, try the website that was giving you the error.
And it worked. I can't thank you enough!
