Breadcrumbs disappears when a text is longer than about 80 bytes. Javascript codes are also missing.
<GOOD>
<BAD>
Please help me to solve this probrem.
First I’d check to see that you’re all patched up, if that doesn’t fix it, you may have run into a limitation of RH. Try downloading a trial copy of RH11 on a non-RH machine and test it using a copy of your project. If it still fails in the same way, log a bug report to get it on Adobe’s radar.
Thank you. I'll try.
Is there any document about limitation of RH?
I confirmed that the version was ”10.0.1.292”. I think that it is the latest enough.
Rather than this being a character limit, this looks more like a corruption. given the repeating of Level 1.
Try creating a new project with a minimal number of topics to prove the point or use one of the supplied sample projects. Click Open on the RoboHelp Starter page and then click Samples in the ribbon on the left.
Mr.Peter Grainge, thank you. I try it.
Unfortunately, no, not explicitly.
Thank you, Mr. Jeff_Coatsworth.
