Uploading Multiple Images
Jul 31, 2007 Jul 31, 2007
Hello,
The answer to this question is most likely sitting right in front of me, but I can not figure this out. This is an image upload page that uploads multiple images to my SQL db. (I am using CF 7.0) I have a form called "pick.cfm" that the user enters the number of images to be uploaded. This page also sets the #cookie.micro# in the code referenced below. #cookie.micro# is the number of images to be uploaded.
The problem is, if I upload two images, for example, named "abc.jpg" and "def.jpg" the filenames are inserted into the database as "abc.jpg" (correct) and "abc1.jpg (not correct).
This is the form:
<cfform action="testingform_action.cfm" enctype="multipart/form-data" method="post">
<cfset numberoffields = #cookie.micro#>
<cfloop index="i" from="1" to="#variables.numberoffields#" step="1">
<cfset filename2 = "form.file">
<cfinput type="File" name="micro" value="#variables.filename2#"/><br />
</cfloop>
<cfinput type="Submit" name="upload" value="upload">
</cfform>
This is the action page:
<cfloop index="i" from="1" to="#cookie.micro#" step="1">
<cffile destination="d:\Inetpub\wwwroot\pulse\pathology\pia\images\"
action="upload"
accept="image/*"
nameconflict="makeunique"
filefield="micro">
<cfquery datasource="pathimage" name="insertimage">
Insert into images (filename) VALUES ('#file.ServerFile#')
</cfquery>
</cfloop>
What is causing this? I am sure it is simple, but I can not figure it out. ANY advice you could give would be so much appreciated!
Alison
Advanced techniques
244
Guide , Jul 31, 2007 Jul 31, 2007
I would guess its because all of the file fields all have the same name. Try naming them dynamically: micro1, micro2, micro3, etc.
A few minor comments about the code
- Afaik, setting the VALUE has no effect for input fields when type="file"
- FILE is deprecated. Use CFFILE.ServerFile instead
- You don't need # signs here <cfset numberoffields = #cookie.micro#>
Not tested
Guide ,
Not tested
Aug 02, 2007 Aug 02, 2007
Thank you SO MUCH for your help! This worked like a charm. I appreciate your time.
Documentation
