1. Re: Change framerate (telecine pulldown) during export
Qengineering Aug 28, 2014 9:29 AM (in response to Elliott B.)Premiere is pretty intelligent about adding proper pull down when changing frame rates.
If you're converting from 23.976p to 29.97i, Premiere should be adding a 3:2 pull down resulting in 3 progressive followed by 2 interlaced frames. The 2:3:3:2 is not an accepted pull down for broadcast, I don't believe Premiere is capable of creating 2:3:3:2.
The only control offered is Field Order (aka Field Dominance) which should always be Upper, First, Odd etc. for HD material.
It's interesting you say the same MXF file shows 2:2:2:4 when opened in Premiere but 3:2 when opened in DaVinci. Personally, I would try to play the MXF in a 3rd party app, step through frame by frame and see what pull down it shows and assume that 2 outta 3 apps are probably giving the true answer. Let us know.
Also, try exporting to another 29.97i format (i.e. MOV) and see if it's the MXF causing confusion.
2. Re: Change framerate (telecine pulldown) during export
Qengineering Aug 28, 2014 10:02 AM (in response to Qengineering)I just did a test from a 1080 @ 23.976 sequence, exporting Format: DNxHD MXF OP1a, Preset: DNX 220 1080i 59.94, Video Codec Resolution: 1080i/29.97 DNxHD 220 8-bit. When bringing MXF file back into Premiere CC (7.2.2) the file has proper 3:2 pull down for broadcast.
3. Re: Change framerate (telecine pulldown) during export
Mark Mapes Aug 29, 2014 9:43 PM (in response to Elliott B.)The apparent duplicate frame every 5th frame is a result of the monitor's playback mode, which defaults to Display First Field. If you switch that to Display Both Fields, you'll get a better sense of how Premiere converts from 24 to 30 fps.
4. Re: Change framerate (telecine pulldown) during export
Elliott B. Aug 30, 2014 12:53 AM (in response to Mark Mapes)Thanks, that is helpful to know.
