I am trying to install adobe flash player, but each time an error message reads that I have to close safari, but when I do and retry the installation, it never finishes and the installation is unsuccessful. How can I fix this?
I'm having the same problem, and Safari is definitely NOT running. It doesn't appear in the Activity Monitor or the program switcher. The installer won't install Flash Player until I quit Safari, but Safari isn't running, so I can't quit it, so I can't install this version of Flash Player. This is pretty clearly a bug. There is nothing I can do to make it work. It's asking me to do something I can't do.
Apparently the installer mistakenly reports that Safari is running when certain other applications that use the same WebKit framework, like Dashboard, for example, are running. There are several ways to get around this:
Adobe could make this process a lot easier if they would make the installer a little more intelligent about reporting process names and providing a more convenient way to quit them if necessary. Apparently they don't think it's worth the trouble, so I guess you have to ask yourself if Flash is worth the trouble.
