Using robohelp 10 on win 7
I have 5 conditional tags in my RH project. In some cases the text may be tagged with more than one conditional tag.
I want to batch remove one tag from the content so all the content no longer uses this tag.
Do I simply delete the tag from the conditional build pod?
If not, how do I do it?
Just hit the Delete key and Rh will tell you it will remove the tag from content. In my experience, it does. Test it in a dummy project if in doubt.
Also anything like this, if not sure, back up first.
Deleting the tag (right click on tag>delete) in conditional tag pod opens a dialog indicating all the tags will be removed from content. Choosing OK to this removes all the tags.
Thank you.
