Locked
Run from CD
Sep 03, 2014 Sep 03, 2014
I have built a Desktop application with captive runtime that runs OK when I run it from my hard disk, when i burn everything to a CD the application doesn't start, it shows a white screen but never loads the intro.
My question is if the exported applications can run from a CD in general or if there is something wrong with my code.
Thanks in advance.
368
Community Beginner , Dec 05, 2014 Dec 05, 2014
Problem solved !!! I managed to run the application, either  by burning the CD from a MAC, which writes it in Hybrid CD format, or on Windows using UDF filesystem and not ISO I was burning it to.
Advocate ,
Sep 09, 2014 Sep 09, 2014
This is errors in your code only. I done many different CD/DVD and it's works.
Do you copy to CD folder with all files from Adobe AIR app?
Sep 12, 2014 Sep 12, 2014
I have found where the problem is. It hangs at code:
homeAssetManager.enqueue(appPath.resolvePath("assets/home"));
where:
private var homeAssetManager:AssetManager = new AssetManager();
var appPath:File = File.applicationDirectory;
Any ideas why it hangs? I'm suspecting it tries to write to the directory. Should I in a way declare that the directory is read-only?
Advocate ,
why not code directly homeAssetManager.enqueue(File.applicationDirectory.resolvePath("assets/home"));
Also I don't know what you doing inside homeAssetManager
I did code it directly as homeAssetManager.enqueue(File.applicationDirectory.resolvePath("assets/home"));
but obviously this wasn't the problem.
Does AssetManager enqueue assets from read-only directories?
Advocate ,
This is your AssetManager How I can know this? )
I don't know how you loading your files and etc. I used Adobe AIR on CD / DVD and don't have any issues with resources loading.
It is not my Asset Manager, it's the starling.utils.AssetManager.
