Hi again
Sorry about that. Are you using RoboHelp HTML? If so, the
application is divided into two main areas. The left side of the
screen is the Project Explorer pane. The right side is where the
WYSIWYG editor is. I'm referring to the left side of the
application.
On the left side of the application are what I refer to as
"Pseudo folders". If you expand them, you may see the contents. One
of these should be named "Skins". If you expand it, you should see
your skin listed. From there, just double-click the skin and the
skins editor should display. The skins editor is pretty
straightforward, so I'll stop here.
Cheers... Rick
