1. Re: Where do I turn on a module inside Business Catalyst?
Liam Dilley Sep 3, 2014 9:45 PM (in response to christevenson)You need to provide more information then that Chris.
If it is a content holder - site manager - content holders.
If the content is removed from a page etc then you need to add it back in.
If it is a web app item then you need to go to that item and enable it.
You do not turn on reports, you just go to it in the admin menu on the left.
IF you are referring to features you do not see when you login in to admin either the site create has not given you permission to access those features OR you are on a plan that does not support them.
2. Re: Where do I turn on a module inside Business Catalyst?
christevenson Sep 3, 2014 9:51 PM (in response to Liam Dilley)I'm sorry I don't mean to be vague, I get this {module_menu,14623} where my header should be, and none of the photos are displaying on the site. I wasn't sure how to correctly ask, I'm pretty new to all this.
3. Re: Where do I turn on a module inside Business Catalyst?
christevenson Sep 3, 2014 9:54 PM (in response to Liam Dilley)I looked in site manager's content holder and it tells me there is no content holders
4. Re: Where do I turn on a module inside Business Catalyst?
christevenson Sep 3, 2014 9:55 PM (in response to Liam Dilley)In the preview everything looks normal but the live view is where I am experiencing the {module_menu,14623} piece of code where the header should be
5. Re: Where do I turn on a module inside Business Catalyst?
Liam Dilley Sep 3, 2014 10:25 PM (in response to christevenson)That is your menu module, does a menu with ID exist etc?
Hard to help you with this little info sorry.
6. Re: Where do I turn on a module inside Business Catalyst?
christevenson Sep 3, 2014 10:34 PM (in response to Liam Dilley)I know it use to, but I built this site probably two years ago, the last thing I remember doing was hiding the content some how through a check mark box. I can't seem to find this seem box because the developer seems to have changed (UI/UX).
7. Re: Where do I turn on a module inside Business Catalyst?
Liam Dilley Sep 3, 2014 11:09 PM (in response to christevenson)You will have either CSS hidden it with your styles, Or you disabled all the menu items, or you removed the menu from the admin.
8. Re: Where do I turn on a module inside Business Catalyst?
christevenson Sep 3, 2014 11:12 PM (in response to Liam Dilley)The one that jumps out of the choices to me is the disabling of the menu, is this option somewhere I'm not seeing?
Sent from my iPhone
9. Re: Where do I turn on a module inside Business Catalyst?
Liam Dilley Sep 3, 2014 11:32 PM (in response to christevenson)You can not disable the menu, just the menu items. - Site Manager - Menus
10. Re: Where do I turn on a module inside Business Catalyst?
christevenson Sep 3, 2014 11:40 PM (in response to Liam Dilley)Ok thank you for the help, I really appreciated it. I'm going to have to check on these options tomorrow. Hopefully we can continue the conversation tomorrow if I have any further questions.
Sent from my iPhone
