1. Re: SVG graphic appears pixelated
Devendar_kumar Sep 4, 2014 3:23 AM (in response to MPellot)Hi MPellot,
Can you please confirm the Edge Animate version?
We have addressed this SVG Pixilation issue in the latest Edge Animate CC 2014 build available now on Creative Cloud.
you can download trial version of Edge Animate CC 2014 using below link
Please also check this forum post for more details.
Devendra
2. Re: SVG graphic appears pixelated
MPellot Sep 4, 2014 6:56 AM (in response to Devendar_kumar)Hi Devandra,
thank you for your quick respond. I use the latest version of Edge Animate CC. I already saw the post SVG Images Blurred but this will not solve the issue. Is there another workaround?
Best
Markus
3. Re: SVG graphic appears pixelated
Devendar_kumar Sep 5, 2014 11:26 AM (in response to MPellot)Hi Mpellot,
Please provide any test file for checking this issue at my end.
Devendra
5. Re: SVG graphic appears pixelated
ClintRuddle Sep 28, 2014 7:41 PM (in response to MPellot)Hey did you get an answer on this? I am having the same issue.
6. Re: SVG graphic appears pixelated
vivekuma Sep 29, 2014 4:29 AM (in response to MPellot)Hi MPellot, ClintRuddle,
As Mr. Devendra said we had SVG Pixelation issue, which has been addressed out in the latest version of Edge Animate.
But before it was addressed, we had done a workaround to solve the svg pixelation issue. And as the issue has been properly addressed now, we no longer need the earlier workaround. So, you have to manually remove the workaround in the updated Edge Animate composition.
So, here are the steps to resolve your issues: (Use the latest Edge Animate version)
1. In "Position and Size" subsection of the property panel, note down somewhere, the values of "X", "Y", "W" & "H" of an svg file used on stage.
2. In "Transform" subsection of the property panel, change the CSS Transform ScaleX and ScaleY from 10% to 100%.
3. The above change will change the values for "X", "Y", "W" & "H". So, you have to set their values as you have noted down in the first step.
4. Repeat the first 3 steps for every svg file used on stage.
hope it helps,
Vivekuma
7. Re: SVG graphic appears pixelated
vivekuma Sep 29, 2014 4:31 AM (in response to ClintRuddle)Hi ClintRuddle,
See if the above solution helps.
8. Re: SVG graphic appears pixelated
ClintRuddle Sep 29, 2014 11:39 AM (in response to vivekuma)Awesome! That seems to work!
Thanks for your help
9. Re: SVG graphic appears pixelated
ClintRuddle Sep 29, 2014 11:40 AM (in response to vivekuma)Awesome! That seems to work!
