1. Re: convert PDF to XPS
MichaelKazlow Jul 29, 2014 6:46 PM (in response to MaryKate110)Moved to Acrobat SDK
2. Re: convert PDF to XPS
lrosenth Jul 29, 2014 7:59 PM (in response to MichaelKazlow)Why would you want to do this?
PDF is an open international standard (ISO 32000-1:2008) which thousands of supporting applications, hardware, etc. and standardized by over 50 countries around the world!
XPS is a proprietary specification controlled by Microsoft with a VERY limited set of supporting applications.
3. Re: convert PDF to XPS
Test Screen Name Jul 30, 2014 1:58 AM (in response to lrosenth)What you want to automate is the XPS driver. That may be possible, but you're asking in the wrong place, it's nothing to do with Adobe.
4. Re: convert PDF to XPS
KeiWatanabe Aug 1, 2014 1:03 AM (in response to MaryKate110)XPS printer requires every file name to save, I agree it's annoying.
I think writing WSH script (use Shell.SendKeys) is the most easy way.
5. Re: convert PDF to XPS
MaryKate110 Sep 4, 2014 6:41 AM (in response to KeiWatanabe)Hi. Thanks to all of you for replying so quickly. I apologize for not responding sooner - I got put off onto another project and did not want to respond until I tried your suggestions. Using SendKeys does work for this, and I am able to bypass the print dialog and put my files to the name I want.
However, I also have another problem.
Before the print dialog comes up, a warning message is displayed:
WARNING! A script has requested to print an acrobat file. This could print an entire document. Do you want to proceed printing?
I found information which suggested that this could be suppressed by executing the following code
Dim AdobeVersion As Decimal
Dim FilePath As String = My.Computer.Registry.GetValue("HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\App Paths\AcroRd32.exe", "", "")
If IO.File.Exists(FilePath) Then
AdobeVersion = FileVersionInfo.GetVersionInfo(FilePath).FileMajorPart
My.Computer.Registry.SetValue("HKEY_CURRENT_USER\Software\Adobe\Acrobat Reader\" & AdobeVersion.ToString("N1") & "\AVAlert\cCheckbox\cAcrobat\", "iWarnScriptPrintAll", "1", Microsoft.Win32.RegistryValueKind.DWord)
End If
I execute this code before doing my PrintAll statement, and I can see that the code is executed without an error, but I still get the warning. My version of Adobe Reader is 11.0 and I am running under Windows 7.
Any suggestions? I did try sending an Enter key to try to deal with this message as well but my application hung.
