1. Re: Import Data help
George_Johnson Sep 4, 2014 12:47 PM (in response to Frolnocx)Are you importing the form data manually or with JavaScript? Do you want one row in the table in the form to correspond to one row in the data file? Will your users be using Acrobat or just Reader?
2. Re: Import Data help
Frolnocx Sep 4, 2014 1:13 PM (in response to George_Johnson)Okay so my boss will be using this and he is on Acrobat Pro XI. It will be manually as I don't know JavaScript
And what I'm looking for is 1 column of data with multiple rows.
Here is a screen cap of the excel document. This is just a sample I'm using to test. My boss will be working with a file close to this one. So what I'm referring to would be column B, for example, has different values in rows 2-6. In the final .pdf I need all of those values to fill separate form fields. That's what I'm getting hung up on.
Hopefully this is enough info. Let me know if I need to provide more information. Thanks.
