1. Re: BC Gurus responsive template slider
keihamm Sep 5, 2014 10:09 PM (in response to StudioBQ)Looks like you got this resolved. Great job.
2. Re: BC Gurus responsive template slider
Pixel Portal Sep 7, 2014 5:08 AM (in response to StudioBQ)Hi, this occurs if you open the homepage template live on the site via the page template.
The editor within the admin console will wipe out this code "data-orbit" once you save the template.
<ul data-orbit> (about line 28) on the homepage template.
It looks to be the way the editor is trying to keep the code clean - it does not recognise this as valid code so cleans it out.
Suggest if you can, to open the template using DEVELOP mode if accessible (this works) to you or edit it offline then upload.
3. Re: BC Gurus responsive template slider
Pixel Portal Sep 8, 2014 6:19 PM (in response to Pixel Portal)Update to this - stops it breaking in BC Editor - thanks to Nicole @ BC Gurus.
<ul data-orbit="data-orbit">
4. Re: BC Gurus responsive template slider
Nicole - BC Gurus Sep 9, 2014 8:31 AM (in response to Pixel Portal)Megan has the correct answer. For BC Gurus related template issues, please submit a support ticket here: Submit a ticket : BC Gurus
