SOLVED
I Need Assistance with a Hierarchical Collection
Avatar
Level 2
Hello,
I have three collections, A, B, and C. B is a collection
contained within A, and C is a collection contained in B.
When I add a new item to collection C, the item is
temporarily added to the collection correctly and then the
collection is quickly replaced with the last item added. I have
come to this conclusion after watching all items(mutiple items) of
collection C being displayed in a DataGrid correctly only to have
them replaced within a second with the last added item only.
I have modeled the application after the "Contact" sample
with Assemblers, DAOs, config files, etc. If anyone has any ideas
on how to correct this, I would appreciate it. I think it is
probably a setup issue within FDS XML files or something simple,
but I have tried multiple changes with no luck.
1 Accepted Solution
Avatar
Correct answer by
Level 2
Instead of using read-only=true, I was able to use lazy=true
and solve the problem. Thanks again for your time. With your help,
I was able to gain a better understanding of how FDS handles these
collections
Avatar
Level 3
Hello
Need more information from it. What are the associations
among Collection A, B and C? How do you add item to collection C?
William Chan
Avatar
Level 2
Here are some code snippets. Please let me know if you need
additional information.
Another interesting thing I've seen is the code works
correctly if I wait several minutes between adding new players. It
seems to be some type of timing issue in FDS. Thanks!
Load the collections...
private function initComp():void {
parties = new ArrayCollection();
dsParties = new DataService("partyList");
dsParties.addEventListener(MessageEvent.RESULT,
resultHandler);
dsParties.fill(parties);
private function resultHandler(event:ResultEvent):void {
dgParties.selectedIndex = 0;
party = Party(parties.getItemAt(0));
tables = party.tables;
dgTables.selectedIndex = 0;
table = Table(tables.getItemAt(0));
players = table.players;
Add a new player...
private function addPlayer():void {
var tmpPlayer:Player = new Player();
tmpPlayer.playerId = 22;
tmpPlayer.playerName = "Johnny";
tmpPlayer.tableId = 1;
tmpPlayer.startingBalance = 100;
tmpPlayer.seatNum = 1;
players.addItem(tmpPlayer);
Avatar
Level 3
Not sure what your assembler code is. However, it looks like
you persist your player on the player assembler. What I mean you
don't need any player data send to the table assembler to update
table's player. There is a setting in association definition called
read-only. Try set it to true in your table assembler's players
association. By setting this, FDS can determine your creation
sequence
William Chan
Avatar
Level 2
Are you referrig to the setup in the
data-management-config.xml file? Assuming it is, I have tried the
following and it did not work. Is this setup as you suggested? Once
again, thank you very much for your time!
<metadata>
<identity property="tableId"/>
<one-to-many property="players" destination="playerList"
read-only="true"/>
</metadata>
Avatar
Level 3
Yes, it is what I mean. I think it should be configuration
issue, I tried something similar and it worked. Can you send me
your destination definitions to me wichan@adobe.com? I would like
to give it a try
William
Avatar
Correct answer by
Level 2
collections
Avatar
Level 3
Hello,
I was over looked the problem. I found that your player
contain tableid. In object oriented FDS, it works with object not
its id
I just tried your scenario, it worked for me. Your player
should not contain tableid. I can email my application for you as a
sample
William Chan
Avatar
Level 3
hello
The followings are my class definitions
package
import flash.net.registerClassAlias;
import mx.collections.ArrayCollection;
import mx.data.IManaged;
import mx.data.utils.Managed;
[RemoteClass(alias="dataservice.associations.lvl3.Party")]
[Managed]
public class Party
public var id : uint;
public var name : String;
public var tables: ArrayCollection;
package
[RemoteClass(alias="dataservice.associations.lvl3.Table")]
[Managed]
public class Table
public var players: ArrayCollection;
package
[RemoteClass(alias="dataservice.associations.lvl3.Player")]
[Managed]
public class Player
public var lastname : String;
public var firstname : String;
Avatar
Level 3
My function to add player
public function createAssociationsByObjectGraph():void
party = new Party()
party.name = "party1";
party.tables = new ArrayCollection();
party.tables.addItem(new Table());
party.tables.getItemAt(0).players = new ArrayCollection();
player = new Player();
player.firstname = "Apple";
player.lastname = "Red";
party.tables.getItemAt(0).players.addItem(player);
player.firstname = "Bananna";
player.lastname = "Yellow";
party.tables.getItemAt(1).players = new ArrayCollection();
player.firstname = "Orange";
player.lastname = "Orange";
party.tables.getItemAt(1).players.addItem(player);
player.firstname = "George";
player.lastname = "Lucas";
ptDS.createItem(party);
ptDS.commit();
public function addPlayer():void
parties_dg.selectedItem.tables.getItemAt(1).players.addItem(player);
ptDS.commit();
</Script>
<Button click="createAssociationsByObjectGraph()"
label="CreatePartyTablesPlayers"/>
<Button click="addPlayer()" label="addPlayer"
enabled="{parties_dg.selectedItem != null}"/>
