1. Re: Can I display user specific web app data based on their login to a generic secure zone
keihamm Sep 5, 2014 9:01 PM (in response to Grovehouse)Ok, first of all, each client will need to have their own "webapp ITEM". So for instance, you would have a single web app called "survey results". Each item within the web app would be a client. Such as "John Doe". I would use the wysiwyg editor to add survey results (as links to another site) in a list format or what not for each webapp item.( Web app item = client name = many links for surveys that client has filled out.). These links will have to be added manually from what I gather from your scenario. Anyways, to answer your question. Yes. You can display results based on who is logged in. When you are editing/creating a webapp item, you will notice under "more options" something labeled as "Submitted By". When you click "edit" it brings up a search box that allows you to search through your CRM database. Simply find the person/client that you want to show this particular web app item to and select their name. Then save. Now, on the actual page that the client lands on once they log in, you will need to insert the web app module labeled "list of submitted webapp items". By doing so, when John Doe logs in, he can only see what he "submitted"(remember earlier "Submitted By"). Hope this helps
2. Re: Can I display user specific web app data based on their login to a generic secure zone
Grovehouse Sep 8, 2014 6:09 AM (in response to keihamm)Well, that's great. Thanks Keihamm, works like a dream. It was the 'Submitted by' I had overlooked. Once that was done it's great.
