1. Re: Video playbar over items on a slide (HTML5)
Lilybiri Jun 19, 2014 1:15 AM (in response to el_enka)Didn't check it yet, concerning the video playbar, but I suppose you checked the option for the Help image to have it Always on top?
2. Re: Video playbar over items on a slide (HTML5)
el_enka Jun 19, 2014 1:27 AM (in response to Lilybiri)Yes, I have checked the option Place object on Top.
3. Re: Video playbar over items on a slide (HTML5)
northernqueen Jun 19, 2014 4:57 AM (in response to el_enka)Hi there,
No real help, but I have the same problem with an interaction (accordion). Obvioulsy, if you enter a slide on which there is an interaction (haven' t tested it with all of them), this always shows on top in HTML5 output (at least above my popup smart shapes)
Also, it is not active, which is similar to what you described.
4. Re: Video playbar over items on a slide (HTML5)
el_enka Jun 20, 2014 12:15 AM (in response to northernqueen)That's right.
I also have a widget and it is rendered on top, but when I checked the z-index in a published output, this is what the values were:
infoBox = 21
widget = 16
which means that according to these values infoBox should be in top. And on top of everything, when I use object inspector in browser and point on the overlapping area, the infoBox is chosen (as if it was on top).
This would indicate that the error is only in the rendering part, because the code is fine. And since Captivate generates the code right this seems to be a browser issue (although all of them appear to have the same flaw).
It is strange.
5. Re: Video playbar over items on a slide (HTML5)
RodWard Jun 20, 2014 12:31 AM (in response to el_enka)Welcome to the wonderfully inconsistent and unpredictable world of HTML5!
6. Re: Video playbar over items on a slide (HTML5)
el_enka Jun 26, 2014 5:48 AM (in response to RodWard)As it turned out the HTML5 inconsistency is not the problem in this particular case . The problem is in the way Captivate generates the output. Which is - all of the images are in the same div - layered properly and then all of active areas and widgets are in another div layered properly.
Images are drawn first and then over them the rest, which results in widget ending up displayed over any image - even one to be stated to be on top all the time.
I have reported this bug to Adobe, so I hope it will be one day (soon) resolved.
7. Re: Video playbar over items on a slide (HTML5)
Russ_E Sep 8, 2014 12:42 PM (in response to el_enka)I had the same issue.
The only workaround I could come up with is to toggle the visibility of the video to prevent it from showing through.
Hope that helps.
Russ
8. Re: Video playbar over items on a slide (HTML5)
el_enka Sep 8, 2014 11:48 PM (in response to Russ_E)I think I can use this. It is visible that the video disappears, but it is an acceptable solution. Thanks
