Show 2 replies
1. Re: Table widget won't display in Captivate 8
Lilybiri Sep 9, 2014 1:59 AM (in response to Latsy65)More learning interactions (think you are speaking about a learning interaction, not a widget) only have a placeholder on the stage; to see the result you'll have to preview (in browser) and after publishing everything will be OK.
It is certainly not only the table interaction that has such a behavior, did you try out all the interactions?
2. Re: Table widget won't display in Captivate 8
beanie_star Nov 11, 2014 10:26 AM (in response to Lilybiri)I am trying to use the exact Learning Interaction. Yes, in authoring it does not preview but even in preview the display is not correct and there doesn't seem to be any way to resize it in order to fix it.
