advancemal wrote:
> i have a page in asp.net (vb) that references external
data objects (dll file
> in the bin folder) and i wondered if it is possible to
do in coldfusion, i
> would assume javascript would be the only option. it is
sage data objects and
> here is a preview of the code in vb.net.
> Dim oSDO As SageDataObject130.SDOEngine
> Dim oWS As SageDataObject130.Workspace
> sage say any language that supports COM objects will
work, so does javascript
> and how to you add a reference to a dll or tlb file?
ColdFusion has the <object ...> tag and createObject()
function that can
both be used to run com objects. ColdFusion can also execute
command
line syntax with the <cfexecute...> tag.
I am not familiar enough with ASP.NET to know exactly what a
data object
is. Is this just connecting to a database or something else?
For the
form, ColdFusion developers usually use the
<cfquery...> tag.
<cfquery name="myRecordSetVar"
dataSource="myConfiguredDSN"...>
SQL Syntax
</cfquery>
Other then that, you will have to tap somebody who knows
there ASP.NET
details better.
