3 Replies Latest reply: Sep 10, 2014 8:09 AM by Pedro Marques RSS
    can i send email directly from bridge cs6 and cc ?
    mantralightroom Community Member
      hi
      can i send emails directly from bridge cs6 or cc directly from bridge?
      i found this scripts http://kb2.adobe.com/community/publishing/894/cpsid_89450.html
      but i run cs6 and cc under windows 7 sp1 64bit and windows 8.1 64bit
      and i have thunderbird email client
      is there a way to make it work?
      maybe i can install another email client
      thanks
        • 1. Re: can i send email directly from bridge cs6 and cc ?
          Pedro Marques Community Member
          // consult MAILSEND in here: https://github.com/muquit/mailsend and download the app 'mailsend.exe' for windows7 in here:
          // https://github.com/muquit/mailsend/releases/download/1.17b15/mailsend1.17b15.exe.zip
          // unzip it and put the app .exe where you want to use it.
          // I have tested using Bridge to send e-mail using my gmail e-mail account and it works. I only needed to
          // I needed to send e-mails from Bridge using my google account, but first I needed to put on my network the app 'mailsend.exe'(i'm using PCs windows7 , CS6 and a network)
          // All my 20 people team is using it, so I decided to put the app 'mailsend.exe' on a common place on network. I you are using it only on 1 PC you don't need you can put it on its disk.
          // Solution: All you need is to create a bat file that tells 'mailsend.exe' what to do:
          var mailsendBat=File(Folder.temp +"/mailsendBat.bat"); // creates a bat file on the temporary folder
          mailsendBat.open("w")
          // the place where app 'mailsend.exe' file is
          mailsendBat.writeln('"X:\\[someFolder]\\mailsend.exe" \^');
          // my gmail
          mailsendBat.writeln('-t pedro.marques@gmail.com -f pedro.marques@gmail.com \^');
          // the title can have encoding or not (-enc-type "base64")
          mailsendBat.writeln('-cs "utf-8" -mime-type "text/plain" -enc-type "base64" -sub "Ich lerne seit ungefähr zwei Jahren Deutsch" \^');
          // this works for the smtp gmail
          mailsendBat.writeln('-starttls -port 587 -auth -smtp smtp.gmail.com -user "pedro.marques@gmail.com" -pass "[myPassword]" \^');
          // If I want to send an image attachment I use this 1, 2, or more times. If content-type is "multipart/mixed" the inline images don't work. Instead the images will be sent as attachment.
          mailsendBat.writeln('-content-type "multipart/mixed" -attach "C:\\Users\\Public\\imagens\\myImage.jpg" \^');
          // this is the line to send a simple text line with no encoding specified
          mailsendBat.writeln('-enc-type "none" -mime-type "text/plain" -M "one line attachment 1" \^');
          // you can sen inline html that can also have links to inline images
          mailsendBat.writeln('-mime-type "text/html" -enc-type "none" -M "<b>this is a test</b><br><img src="http://[any_online_image.jpg],image/jpeg,i">" \^');
          // sending text line with special encoding
          mailsendBat.writeln('-cs "utf-8" -mime-type "text/plain" -enc-type "base64" -M "Ich lerne seit ungefähr zwei Jahren Deutsch" \^');
          // endind it
          mailsendBat.close();
          // executing
          mailsendBat.execute();
          // there are also other kind of commands (consult https://github.com/muquit/mailsend)
          • 2. Re: can i send email directly from bridge cs6 and cc ?
            wow
            should i create an empty jsx file and paste ?
            and change the folders and add my email account?
            thanks
            • 3. Re: can i send email directly from bridge cs6 and cc ?
              It depends on how you want Bridge to interact with your objectives.
              You might want to use SDK code to have buttons on a panel on Bridge.
              These buttons can read the pre-selected image thumbnails, and get jpgs sorter images on the Temp folder.
              Then a window could open for you to put the e-mail title and the subject and click 'send'
              For now I have no much time to code this, sorry.
