Locked
ERROR ITMS-9000:"This bundle is invalid. New apps and app updates submitted to the App Store must be built with public (GM) versions of Xcode 5.1.1
Jun 03, 2014 Jun 03, 2014
I submitted my IPA file to Itunes Connect using Application Loader and got the error message below. I have AIR SDK 13.0.0.111 and using Flash Builder 4.6.
Please help. Thank you in advance.
ERROR ITMS-9000: "This bundle is invalid. New apps and app updates submitted to the App Store must be built with public (GM) versions of Xcode 5.1.1 or higher and IOS 7 SDK. Do not submit apps built with beta software." ...
4.0K
Jun 11, 2014 Jun 11, 2014
Got it. Updated version to 14.
Engaged ,
Sep 09, 2014 Sep 09, 2014
I just got the same message for an app with 14.0.0.178 for iOS. Is there a new SDK version. It seems we Adobe developers (Flash CC 2014) can´t get a break from Apple...
Advocate ,
Update your Adobe AIR SDK to 15.x that was released today http://www.adobe.com/devnet/air/air-sdk-download.html
Engaged ,
Sep 10, 2014 Sep 10, 2014
This also affects the newest AIR 15 SDK -- it's still using XCode 5.0.2 (which was also used in 14), instead of XCode 5.1.1
Advocate ,
do you have skype? chat to me therabbitflash and can rebuild sdk and you can test if you can submit with my update
Guest
same issue here using AIR SDK 15 (tried 14 also) and get the message "This bundle is invalid - New apps and app updates submitted to the App Store must be built with public (GM) versions of Xcode 5.1.1 or higher and iOS 7 SDK. Do not submit apps built with beta software."
Advocate ,
Could you please try this hotfix sdk labs.gamespoweredby.com/sdk/AIRSDK_Compiler_15_0_0_249_xcode511_hotfix_win.zip and report here could this help?
This is not official release version with GM 5.1.1 support. It's just my custom version
Guest
Sep 11, 2014 Sep 11, 2014
Hello Anton, not sure what your zip contains. I'm on a Mac. Does your hotfix work on Macs? Thanks
Advocate ,
Sep 12, 2014 Sep 12, 2014
My hotfix contain only updated signatures from xcode 5.1.1 gm. I don't know about Mac but I'm sure that you can download my zip, extract and and find there adt.jar file and replace with other one
1) download my zip
2) extract it do desktop
3) go to AIRSDK_Compiler _15_0_0_249_xcode511_hotfix\lib\adt.jar
4) put my adt.jar to your original adobe air sdk but old adt.jar rename for backup
try to compile. this must help in case your app rejected with xcode version error reason
Participant ,
Sep 26, 2014 Sep 26, 2014
Hi!
I'm also using Air SDK 15 and I'm getting  Invalid Bundle Error:
Adobe Air iOS Invalid Bundle
The bundle does not support the minimum version os specified in info.plisthttp://stackoverflow.com/questions/26047837/adobe-air-ios-invalid-bundle-the-bundle-does-not-support...
Really need help
Michael
Oct 02, 2014 Oct 02, 2014
Hello SirRookie,
Finally did you find any solution to the ERROR ITMS-9000 ?
I´m using FB 4.7 and AIR 15 SDK
Any solution ? We have the same error and we need to publish new apps.
Advocate ,
Hello Anton, I have that one installed from AdobeLabs but I get same ERROR. Is working for you ?
Advocate ,
open IPA as ZIP, extract Info.plist and attach it here. Remove CFBundleIdentifier key before so you hide your app id from us for security reason (if you want).
Ok, I´m going to compile it again. The problem is that now I can't install 15 SDK. FB 4.7 tells me that I don't have a valid SDK.
I follow this steps to install it after downloading Download AIR 15 SDK for Flex Developers for Mac OS X From AdobeLAbs
Is that ok ?
Advocate ,
If your project use Flex - download flex. If pure as3 - download sdk (at the middle of sdk labs page).
check release  notes in the labs under date of sdk. On last page you will see the manual how to install it into fb.
Oct 04, 2014 Oct 04, 2014
SOLVED!!! Thanks a lot Anton for your Help. SDK 15 is the solution.
