SOLVED
webservice proxy with fds2
Avatar
Level 2
Hello all,
I am struggling with fds2 and currently fail to use a proxy
for my webservice.
Maybe I also misunderstand something, cause what I want to do
is I want to use the fds/webservice as proxy to gather the calls
and forward it to another webservice (who just accepts the
connections from the proxy pc)
So I configured the service_config.xml and put it into the
additional compiler arguments, but for somehow reason it even
didn´t connect to the webproxy.
Maybe I have to learn more about jrun, but from the
documentation I thought the webproxy configuration is easy to
setup.
Did someone has experience in setting up a similar scenacrio
? (maybe with other application servers)
best regards,
kcell
1 Accepted Solution
Avatar
Correct answer by
Former Community Member
That stream error means that the client still isn't
connecting to your FDS
endpoint... can you check that the endpoint is contactable
from a browser?
Did you look at the server console or server logs for any
configuration errors
during startup?
Pete
Avatar
What URL are you using to load your SWF and how does this
compare to the
URL used in the channel-definition endpoint to contact the
proxy service?
Avatar
Level 2
Hi Peter,
So my current installation looks like the follwing:
Server A:
- Apache server for SWF file
- JRun server for the webservice proxy
- (also my development machine)
Server B
- IIS with and ASP webservice
I have played around with the entries in service-config.xml
and proxy-config.xml files, so I here is the current state (which
is still not working):
service-config.xml:
<channel-definition id="myWS"
class="mx.messaging.channels.HTTPChannel">
<endpoint uri="
http://anhalt/OMTest/"
class="flex.messaging.endpoints.HTTPEndpoint"/>
</channel-definition>
proxy-config.xml:
<destination id="myWS" adapter="soap-proxy">
<adapter ref="soap-proxy" />
<properties>
<wsdl>
http://anhalt/OMTest/Service1.asmx?WSDL</wsdl>
<soap>
http://anhalt/OMTest/</soap>
</properties>
</destination>
One thing I have done (which might be wrong) was that I
removed the "{context.root}" from most service, cause otheriwse I
couldn´t compile the mxmml ( I used destination="myWS" and the
service-config.xml is the same as Jrun used. )
Would it help if I post the debug output (with mx:TraceTarget
on )?
Thank you,
kcell
Avatar
Level 2
Hi Peter,
I now found what the {context.root} is used for (and that
there is another compiler setting ( ... -context-root=/helloworld
..) , but the webproxy is still not running as expected.
best regards,
kcell
Avatar
Ah, you've confused what a channel endpoint is, and what the
proxy service
will "proxy" for your when contacting your WebService.
Your channel-definition endpoint should NOT be pointed at
your WebService
- it should be pointed at the FDS server endpoint as it has
the proxy service
that you want to proxy through.
However, you may have complicated things by having an Apache
server and a
JRun server on Server A (unless you've successfully used a
connector so that
Apache redirects requests to JRun?). If you are using a
connector and Apache
and JRun receive web requests on the same port then you could
do this:
<endpoint uri="
http://{server.name}:{server.port}/helloworld/messagebroker/http"
But, if you have different ports for calling your SWF from
apache and sending
data to FDS on JRun, then you can't rely on {server.name} and
{server.port}
tokens, so it would have to look something like this:
<endpoint uri="
http://yourjrunserver:8100/helloworld/messagebroker/http"
But, in order for your SWF loaded from
http://yourapacheserver:8080/yourapp.swf
to contact
http://yourjrunserver:8100/...
you'd need to host a crossdomain.xml
file at
http://yourjrunserver:8100/crossdomain.xml
and setup a policy so
that at least SWFs from yourapacheserver can contact it (I
hope you see why
it's easier to host SWFs on the same web application server
as FDS so that
you can avoid these security sandbox considerations! ).
(...and note you can rely on the {context-root} token instead
of hard coding
"/helloworld" into the endpoint location now that you're
aware of the -context-root
compiler argument).
Then, your proxy-service destination should look something
like this:
<properties>
<wsdl>
<soap>
http://anhalt/OMTest/*</soap>
</properties>
</destination>
The reason is that you first need to get the Flash Player to
connect to FDS,
and then FDS's proxy service will end up contacting your web
service.
Another alternative is to just take FDS out of the picture
entirely if you
control the contents of the server hosting your .NET web
service. Simply
setup a /crossdomain.xml policy file on that IIS server and
you don't need
to use a proxy or FDS at all.
Avatar
Level 2
Hi Peter,
thanks for you detailed answer, but it still doesn´t
work. :(
I have the impression that the proxy service of jrun
doesn´t run (for somehow reason), cause the debug ouput shows
9BA8EE4D-EEFC-BC96-47F3-45E1BCAC235E' producer channel
faulted with Channel.Ping.Failed [IOErrorEvent type="ioError"
bubbles=false cancelable=false eventPhase=2 text="Error #2032:
Stream Error. ....
How can I test if the proxy runs under the expected URL like
Should the webbrowser show something? Should netstat -ano
show a listening service at the port?
The system structure is made cause the customer didn´t
want any IIS/MS pcs outside of the firewall (security). So our
first thought was to put the FDS/lifecycle as proxy outside the
firewall. We also know that FDS can more much more things .
Beside this problem I like to ask if you an recommend a book
to get more infos about the FDS/lifecycle or also Jrun?
best regards,
kcell
Avatar
Correct answer by
from a browser?
during startup?
Pete
Avatar
Level 2
Hi Pete,
found it finally. As you mention the endpoint was not
contactable, tried with the default "/flex/messagebroker/http" and
it worked, so the fault was that I used a "context-root", which was
not valid.
I guess I have to build my own app/context and use this one.
Never worked with java appliaction servers before, so I think
I have to learn a lot.
Thank you very much for your help and patience ;)
best regards,
kcell
The following has evaluated to null or missing: ==> liqladmin("SELECT id, value FROM metrics WHERE id = 'net_accepted_solutions' and user.id = '${acceptedAnswer.author.id}'").data.items [in template "analytics-container" at line 83, column 41] ---- Tip: It's the step after the last dot that caused this error, not those before it. ---- Tip: If the failing expression is known to be legally refer to something that's sometimes null or missing, either specify a default value like myOptionalVar!myDefault, or use <#if myOptionalVar??>when-present<#else>when-missing. (These only cover the last step of the expression; to cover the whole expression, use parenthesis: (myOptionalVar.foo)!myDefault, (myOptionalVar.foo)?? ---- ---- FTL stack trace ("~" means nesting-related): - Failed at: #assign answerAuthorNetSolutions = li... [in template "analytics-container" at line 83, column 5] ----
