Hi everybody,
At present i'm generating a HTML Help File using RH6.
I've created a template and created a table in the Header
part and placing an Image in one of the row.
I've 3 constratins in it:
1. I'm not able to Insert DHTML Effects for the Images. I
need to place the image inside the body text and then give the
effects and then paste the same inside the header.
Why am i not able to give DHTML Effects inside the Header.
2. The same constraint is for Image Maps. Not able to insert
image maps to the images present inside the Headers.. Again i'm
doing it in the body text and then pasting the same inside the
header.
3.Once when i pasted the Image (image map inserted in the
body text and pasted to the header), in the Header part of the
Template, and apply them to the topics, the image map gets
disappeared....however it is present in the template (the image map
works when i view the template alone)..it is not present in any of
the topics...
Are these bugs(sorry if i've pointed out incorrectly) or is
there any another ways to rectify these.
