1 Reply Latest reply: Sep 19, 2014 4:31 PM by Jesse... RSS
    Property inspection panel vanished - Fireworks CS6
    Helena Green Community Member
      The property inspector panel became un-docked in Fireworks CS6 and vanished from the bottom of my screen.  Pressing F4 (or Tab) re-displays the panels but not the property inspector.  I cannot find any help to restore this functionality to my software - can anyone help?
      http://www.pinterest.com/pin/create/extension/
        • 1. Re: Property inspection panel vanished - Fireworks CS6
          Jesse... Community Member
          A lot of glitches in Fireworks can be solved by deleting the preferences file. First you will have to make sure your Library folder is viewable and you are accessing the root folder on your hard drive. In recent releases of Mac OS, it is hidden by default.
          First, show your Hard Drive by following these directions:
          1. In the Finder, choose Preferences from the Finder menu.
          2. Click the General icon on the toolbar.
          3. Select "Hard disks" in the "Show these items on the desktop:" section.
          4. Close the Finder Preferences window.
          Next, you'll have to unhide the library folder by following these instructions:
          In the Finder, choose View > Show View Options (or press Command-J).
          Near the bottom of the resulting View-Options palette is a setting called Show Library Folder. Enable this option. Your Library folder is immediately visible.
          In that folder, find the Preferences folder. Then in the preferences folder, find the file with this name (or similar): "com.adobe.Fireworks.12.0.0.plist" and delete it.
          Restart your machine and Fireworks and your problem may be solved.
