1. Re: Coldfusion 11 - Web Sockets via SSL
Sharma Nimit Sep 10, 2014 10:02 PM (in response to cgjazinski@upta.edu)Hi,
If you are trying to configure WebSocket over SSL using self-signed certificate, then ColdFusion server should also be running over SSL using the same certificate.
To configure ColdFusion server over SSL follow below mentioned steps:
1. Create Keystore:
Keytool -genkey -keyalg RSA -keystore websocket.crt -storepass changeit -alias wss -keypass changeit -validity 365
2. Configure ColdFusion to run over SSL port:
- Uncomment "<Connector port="8443" protocol="HTTP/1.1" SSLEnabled="true" maxThreads="150" scheme="https" secure="true" clientAuth="false" sslProtocol="TLS" />" this section in server.xml file available at <cf_home>/cfusion/runtime/conf.
- Change value of "Protocol" attribute from "HTTP/1.1" to "org.apache.coyote.http11.Http11NioProtocol" in the Connector tag.
- Add these attributes to above mentioned tag:
- keystoreFile
- keystorePass
- Save Changes.
- Restart ColdFusion service.
- Access ColdFusion administrator console using URL: https://127.0.0.1:8443/CFIDE/administrator/index.cfm
3. Configure Websocket to run over SSL port:
- Access ColdFusion administrator console.
- Navigate to ColdFusion Administrator > Server Settings > WebSocket.
- Check "SSL Port" checkbox.
- Enter keystore location and password [which we created in step #1 Create Keystore ].
- Submit Changes.
4. Create a sample CFML template to verify the configuration.
Application.cfc
component
this.name = "sample";
this.wschannels = [{name="demo"}];
SAMPLE.cfm
<html>
<head>
<title>Websocket Example</title>
<script>
//messagehandler recieves all the messages from websocket
function mycbHandler( messageobj)
var message = ColdFusion.JSON.encode(messageobj);
var txt=document.getElementById("myDiv");
txt.innerHTML +=message +"<br>";
//openhandler is invoked when socket connection is
function openHandler()
txt.innerHTML +="open Handler invoked <br>";
</script>
</head>
<cfwebsocket name="mywsobj" onMessage="mycbHandler" subscribeTo="demo" onOpen="openHandler" secure="true"/>
<div id="myDiv"></div>
</html>
5. Try to access this CFML template using ColdFusion over SSL port using Chrome web browser or any other browser with debugging capability.
6. In my case, it is Google chrome. Press F12 and navigate to the Network section to check whether websocket request is being served over SSL or not.
If you find any difficulty in following above mentioned steps, you can contact me at nimsharm@adobe.com
Nimit
2. Re: Coldfusion 11 - Web Sockets via SSL
Prem Radhakrishnan Oct 27, 2014 12:04 PM (in response to Sharma Nimit)Hi Nimit,
I am trying to follow the same instructions presented here with little success, I was directed here by my developer who is trying to implement WebSocket over SSL on ColdFusion 11. We are running ColdFusion 11 on Windows Server 2012 and IIS 8. We are using a GoDaddy certificate and not a self-signed certificate, should the process be the same?
Basically, I have used the keytool as described and made the changes in server.xml and restarted the server but I cannot access the page on port 8443 or on just HTTPS. It just says waiting and eventually times out. I can access the regular coldfusion admin on HTTP. Could you please help me troubleshoot this ? I am looking at the logs and cant find anything helpful.
Regards
Prem
