Show 6 replies
1. Re: dataLabelStyle="value"
Newsgroup_User Feb 12, 2009 9:15 PM (in response to trojnfn)just a thought: did you set datalabelstyle="none" for the other 2 series?
Azadi Saryev
Sabai-dee.com
http://www.sabai-dee.com/ -
2. Re: dataLabelStyle="value"
Newsgroup_User Feb 12, 2009 9:19 PM (in response to trojnfn)suggestion: for complicated charts (multiple series, vaiuos scales for
series, etc etc) it is best to fire up webcharts (comes with cf) and
create you chart there, then export the xml style of that chart and
point your cfchart' STYLE attribute to that file.
webcharts in single-server cf on win can be found in:
{cf_install_dir}\charting\webcharts.bat
it may take a while to figure out how to use it properly, so google
around - there are blog posts on the topic with tips and examples.
hth
Azadi Saryev
Sabai-dee.com
3. Re: dataLabelStyle="value"
trojnfn Feb 12, 2009 9:44 PM (in response to Newsgroup_User)Yes, I tried it with none and and all three still display. If I have the cfchartseries with datalabelstyle first and then the other two, none of the data displays. If I have it last, then all 3 display. This is weird. I only want the display on one of the cfchartseries. -
4. Re: dataLabelStyle="value"
Dolfan Alex Sep 11, 2014 6:30 AM (in response to trojnfn)I am sorry to see there was never a solution here. I have the same issue.
5. Re: dataLabelStyle="value"
Dolfan Alex Sep 11, 2014 7:11 AM (in response to trojnfn)I ran webcharts.bat and even in the designer, it seems like a global variable unfortunately (running CF 10 here). So at least as of CF10 I don't think there was a way to do this.
6. Re: dataLabelStyle="value"
BKBK Sep 12, 2014 1:54 AM (in response to Dolfan Alex)@Dolfan Alex
It will be more fruitful to start your own new thread. The technology, Coldfusion versions and people have moved on.
