I'd like to start by saying I didn't have this issue on CF9 Standard but recently updated to CF10 and now have the issue.
I have a site and several sub domains running on IIS and CF10. They are all set up as separate sites but share a wildcard SSL certificate for *.domain.com
forums.domain.com
community.domain.com
etc.
I'm doing cfhttp calls between the sites. They work fine over http but over https, I get the all too common 'I/O Exception: peer not authenticated' error.
Charset [empty string]
ErrorDetail I/O Exception: peer not authenticated
Filecontent Connection Failure
Header [empty string]
Mimetype Unable to determine MIME type of file.
Responseheader struct [empty]
Statuscode Connection Failure. Status code unavailable.
Text YES
So I figured I needed to install the SSL certificate. I've installed the certificate in the correct key store and verified it's there using keytool -list and restarted. I even tried uninstalling and reinstalling it using the CertMan admin plugin but still get the error.
I know there are other work arounds for this problem with Enterprise but as I'm running standard I can't use them.
Does anyone have any suggestions? I'm pretty much stumped without https.
Richard
Have something to add?
