3 Replies Latest reply: Sep 11, 2014 12:17 PM by RoboColum(n) RSS
    Can RH server host JavaDocs?
    kdeuler Community Member
      Hi. Can RH server host JavaDocs, or can it only host WebHelp Pro/Flash Pro.  I'd like to publish JavaDocs but use the authorization features built in to RS Server.
      Perhaps there's a utility for importing JavaDocs into a RH project, and from thence to a WebHelp Pro output?
      Thanks.
      -Kurt
        • 1. Re: Can RH server host JavaDocs?
          RoboColum(n) MeganK
          Please correct me if I am wrong but JavaDocs is just a collection of HTML files, right? If so, you could import these into your RH project and output to WebHelp Pro or FlashHelp Pro. You may have to do a little tidy up of the files after importing them. It all depends on the way the JavaDocs files are created.
          • 2. Re: Can RH server host JavaDocs?
            That's right. It's a collection of HTML files. I'll see if there's ways to import them easily.
            • 3. Re: Can RH server host JavaDocs?
              RoboColum(n) MeganK
              You can import HTML files from the File > Import menu in RH. The problem you may have is that the JavaDocs may have scripting or code that RH does not understand. I had a similar scenario several years ago abd I was able to get a workable solution by assigning a style sheet and doing some find and replace operations. It may require some testing, but once you have it sorted it would be easy enough.
