I cannot find the latest update 15.0.0.152 ActiveX in the Flash Player SCUP (2011) catalog?
Does anyone know if there is just a delay in updating it there or why it cannot be found?
According to the information from Adobe, it should be included.
Best regards,
Henri
Yeah, that is the one I use (same address for the cab as the "built-in" partner catalog for Flash), but the latest update to the catalog only has the the versions from July/August ActiveX 14.0.0.176 and Plugin 14.0.0.179. So, I do not get why the 15.x version is not there.
I just downloaded the cab file and looked at the XML - it seems to me that Adobe has made a mistake. Note the bulletin APSB14-21 ID below, which is the latest, but then the version data is all referring to version 13 of the Flash Player
http://www.adobe.com/products/flashplayer and the release notes at http://www.adobe.com/go/flashplayer_releasenotes</sdp:Description></sdp:LocalizedProperties><sdp:UpdateSpecificData MsrcSeverity="Important" UpdateClassification="Security Updates"><sdp:SecurityBulletinID>APSB14-21</sdp:SecurityBulletinID><sdp:KBArticleID>APSB14-21</sdp:KBArticleID></sdp:UpdateSpecificData><sdp:InstallableItem ID="f56d74ae-3133-4182-ade0-ada284f53f23"><sdp:ApplicabilityRules><sdp:IsInstalled><lar:And><bar:RegDword Key="HKEY_LOCAL_MACHINE" Subkey="Software\Macromedia\FlashPlayer\SafeVersions" Value="13.0" RegType32="true" Comparison="GreaterThanOrEqualTo" Data="244" /><bar:RegKeyExists Key="HKEY_LOCAL_MACHINE" Subkey="Software\Classes\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}" RegType32="true" /></lar:And></sdp:IsInstalled><sdp:IsInstallable><lar:And><bar:RegKeyExists Key="HKEY_LOCAL_MACHINE" Subkey="Software\Classes\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}" RegType32="true" /><lar:Not><bar:RegDword Key="HKEY_LOCAL_MACHINE" Subkey="Software\Macromedia\FlashPlayer\SafeVersions" Value="13.0" RegType32="true" Comparison="GreaterThanOrEqualTo" Data="244" /></lar:Not><bar:WindowsVersion Comparison="GreaterThanOrEqualTo" MajorVersion="5" MinorVersion="0" ServicePackMajor="0" ServicePackMinor="0" /><bar:WindowsVersion Comparison="LessThan" MajorVersion="6" MinorVersion="2" ServicePackMajor="0" ServicePackMinor="0" /></lar:And></sdp:IsInstallable></sdp:ApplicabilityRules><sdp:InstallProperties CanRequestUserInput="false" RequiresNetworkConnectivity="false" Impact="Normal" RebootBehavior="NeverReboots" /><msi:MsiInstallerData ProductCode="{757B0EDB-B853-4CF7-A2CD-965659D1ADB7}" MsiFile="install_flash_player_13_active_x.msi" /><sdp:OriginFile Digest="z3fP8KQFctcFR33NOBudUQNkJjU=" FileName="install_flash_player_13_active_x.msi" Size="18457600" Modified="2014-08-27T08:04:46.573Z" OriginUri="http://download.macromedia.com/pub/flashplayer/current/licensing/win/install_flash_player_13_active_x.msi">
I am also having the same experience. The update catalogue does not have the 15.0.0.152 updates in it only 14.0.0.176
I have the same experience here for the Backgorund Update Resources .cab File!
Same here, but my SCUP says the provided cab file is from Aug 4, 2014. The newest SecurityBulletinID in the xml file is APSB14-18.
Hello all,
We are aware of an issue with some locale's getting the older files and other locales getting the newer files. We apologize for this and are working to resolve this issue. I'll post back here, in this thread, when this is fixed.
Maria
We are still working our our CDN provider to resolve this issue.
Maria
Thanks Adobe - now there is a new catalog refresh for SCUP, which includes the correct 15 version!
Yep, new catalog is visible here too. Many thanks!
Thank you very much for confirming you're now getting the new catalog.
Maria
