Locked
Need to save .SVG text as draw with vector graphic tools like line, circle, rect and then save to local file.
Sep 12, 2014 Sep 12, 2014
I have written an image generator that draws using flash.display.Graphics like circle, rect and line.  I need to save the .svg text for each command and write the result to a vector. svg file so the resulting drawing can be subsequently resized without loss of detail.
285
Sep 13, 2014 Sep 13, 2014
     figured it out myself.  This is the class I created - it's all I need:
package classes
  import flash.geom.Point;
  public class drawSVG
   public var svgData:String = "";
   private var svgID:Number = 1;
   public function drawSVG()
   public function start(svgTitle:String,inw:Number,inh:Number,inAngle:Number) : void
   svgData = '<svg width="' + inw.toString() + '"' + ' height="' + inh.toString() + '"' +
                     ' x="' + -inw/2 + '" y="' + -inh/2 + '" xmlns="http://www.w3.org/2000/svg">\r\n';
   svgData += '<g transform="rotate(' + inAngle + ' ' + '0' + ' ' + '0' + ')">\r\n';
   svgData += '<title>' + svgTitle + '</title>\r\n';
  public function drawLine(inStrokeClr:String,inStrokeW:uint,
            inAngle:Number=0) : void  // angle in degrees
   if (inStrokeW != 0)
     var x1:Number = inx + inw/2;
     var y1:Number = iny - inh/2;
     var x2:Number = inx + inw/2;
     var y2:Number = iny + inh/2;
     var svgStrokeClr:String = inStrokeClr.split("0x").join("#");
    svgData += '<line x1="' + x1 + '" y1="' + y1 + '" x2="' + x2 + '" y2="' + y2 + '"';
    svgData += ' style="';
    svgData += ' stroke:' + svgStrokeClr + ';stroke-width:' + inStrokeW;
    svgData += '"';
    svgData += ' id="line_' + svgID.toString() + '"';
    svgData += '/>\r\n';
public function drawEllipse(inStrokeClr:String,inStrokeW:uint,
   if (isFill || inStrokeW!= 0)
     var svgFillClr:String = infillClr.split("0x").join("#");
     svgData += '<ellipse rx="' + inw/2 + '"'' ry="' + inh/2 + '"' +
                        ' cx="' + inCenterX +'"' + ' cy="' + inCenterY + '"';
     if (isFill)
        svgData += ' fill:' + svgFillClr;
     if (inStrokeW!= 0)
        svgData += ' stroke:' + svgStrokeClr + ' stroke-width:' + inStrokeW;
     svgData += '"';
     svgData += ' id="ellipse_' + svgID.toString() + '"';
public function drawRectangle(inStrokeClr:String,inStrokeW:uint,
                           isCenter:Boolean,inAngle:Number=0) : void  // angle in degrees
     var x:Number = (isCenter ? inx-(inw/2) : inx);
     var y:Number = (isCenter ? iny-(inh/2) : iny);
     svgData += '<rect x="' + x + '" y="' + y + '"' +
          ' width="' + inw + '" height="' + inh + '"';
     if (isFill)
     if (inStrokeW!= 0)
         svgData += ' stroke:' + svgFillClr + ' stroke-width:' + inStrokeW;
     svgData += '"';
     svgData += ' id="rect_' + svgID.toString() + '"';
public function terminate() : void
   svgData += "</g>\r\n";
   svgData += "</svg>";
