1. Re: all my code in edge code are grey color...how can change the color of tags and elements?
Peter Flynn (Adobe) Sep 12, 2014 11:47 AM (in response to OTHAR Drummer)What is the file extension of the file you're editing? If Edge Code doesn't recognize the file extension, it will not know what type the file is, and you won't get any syntax coloring. The status bar in the lower-right corner should say what file format Edge Code thinks the file is -- does it say Text, or something else like CSS or HTML?
>> i follow the tutorial for add brackets
Can you link to the tutorial? I'm not sure what you're referring to.
- Peter
2. Re: all my code in edge code are grey color...how can change the color of tags and elements?
OTHAR Drummer Sep 14, 2014 2:53 AM (in response to Peter Flynn (Adobe))ups..thanks Peter.i forget to save with .html . it works !!!
i follow the tutorial for add brackets , but mi last line before insert code lines to enable is not the same..
i tried to add after and before this , my last line , and no works...
" linting.enabled_by_default":false },
this is my las line..
i don´t know where must add the four code lines that shows tutorial .
thanks Peter
3. Re: all my code in edge code are grey color...how can change the color of tags and elements?
Peter Flynn (Adobe) Sep 15, 2014 1:05 PM (in response to OTHAR Drummer)Can you post a link to the tutorial you're reading? I'm not sure what steps you're following, so it's a little hard to understand what you're describing.
- Peter
4. Re: all my code in edge code are grey color...how can change the color of tags and elements?
OTHAR Drummer Sep 22, 2014 11:57 AM (in response to Peter Flynn (Adobe))Yeah..i saw.thanks man.i work very speed first time i try edge code.now works !.
Enviado de Samsung Mobile
