Show 2 replies
1. Re: RoboHelp for HTML 9 - Problem with viewing .chm file on 64bit machine
Willam van Weelden Sep 15, 2014 5:11 AM (in response to Givi5)This issue is normally related to opening a CHM which is stored on a network location. So please make sure that the CHM is saved on a local drive AND that the CHM is unblocked. (You do that in the file properties.)
Kind regards,
Willam
2. Re: RoboHelp for HTML 9 - Problem with viewing .chm file on 64bit machine
Captiv8r Sep 15, 2014 8:06 PM (in response to Willam van Weelden)Generally, I've only ever seen the need to ensure the CHM is unblocked if it has been downloaded from the web. I could see where it could possibly occur if one moved the CHM from a network drive to a local drive, but I'm skeptical that would be required in that case.
Cheers... Rick
