Hi again
Problem solved by our skilled Chinese and Czech contacts :-)
Edit the corrupted characters in
\!SSL!\WebHelp\whxdata\whtdata0.xml and similar files (in Notepad),
and change the encoding from "windows-1252" to the relevant code
(1250 for Czech). Then save it as ANSI, not Unicode.
(additional info from our Czech contacts)
Moreover, it seems that all of the XML files in the whxdata
folder need to be
fixed in the same manner - they contain language data for the
index and search
as well, apart from the TOC. Also, whfform.htm, whiform.htm,
whskin_tbars.htm in the WebHelp folder need to be fixed by
inserting the following line into the
<head> section:
<meta http-equiv="content-type" content="text/html;
charset=**">
(for example, ** is windows-1250 in case of Czech)
Hope this can be of use :-)
Torgeir
