I had same problem with x64 vista found answer
Open C:\Windows\SysWOW64\odbcad32.exe and create a System DSN using the Microsoft Access Driver (*.mdb).
Then open the ColdFusion Admin and create a datasource using the ODBC Socket driver.
Check the Trusted connection checkbox and it should work.
@jimmoos
Your solution is clean and works! No messing around with registry entries.
I have x64 Windows 7. I took myself backwards and was able to reinstall my ColdFusion MX 6.1 software. It was also my first time to use the "ODBC Socket driver" option. Upto this point I had always used the other drivers (native ones)
Thx buddy
Thanks so much for the info! I have Windows 7 x64bit with
Coldfusion 6.1. I'm just developing for myself so didn't want to upgrade. This solution worked perfectly. Thanks again!
I'm having the same problem, but when I try to create a SYSTEM DSN, I don't have a Microsoft Access option. I only have SQL Server and SQL Native Client. Any suggestions? Thanks!
That's a clean solution, but the MS Access DSN I add in System DSN does not show up in the "ODBC DSN" select box in the Datasource creation form in the CF Admin at
Data & Services > Datasources > ODBC Socket
so when I submit the form I get this error:
A ODBC Datasource must be selected before submitting changesCopy link to clipboard
I had similar issues. Fixed them by installing the 64-bit drivers from here: http://www.microsoft.com/en-us/download/details.aspx?id=13255
Then I had to add the System DSN in the 64-bit ODBC Management Console, which causes it appear in the ODBC DSN drop-down on the CF Admin Data Source form.
Then had to add the same System DSN to the 32-bit ODBC Management Console, to fix this error when CF attempts to connect to the database:
Connection verification failed for data source: PABasketballSSJ
java.sql.SQLException: [Macromedia][SequeLink JDBC Driver][ODBC Socket]internal error: The specified DSN contains an architecture mismatch between the Driver and Application
The root cause was that: java.sql.SQLException: [Macromedia][SequeLink JDBC Driver][ODBC Socket]internal error: The specified DSN contains an architecture mismatch between the Driver and Application
