Hello I cannot login with my adobe-ID on a second computer. may be I use the wrong format:
Iused only the string and also with leading URN:uuid -- but it doesn't work
email: huesken.michael@arcor.de@
hi,
you just need to enter the email id and not URN::uuid.
Hi.
thank you for your help -- a little advice will be helpful, that email should be used and not the number.
it is working.
Kindly Regards
Michael
Similar problem. I keep getting asked for vendor ID which doesn't exist. Chat useless. Obvious Adobe doesn't support this product. So will try to find an alternate software to read e-books.
It doesn't work. Adobe won't support it.
Select "AdobeID" in the eBook Vendor dropdown and then authorize with your Adobe ID as email ID.
You can also use any other email ID to authorize, in which case the eBook Vendor dropdown needs to be changed to the Vendor(from its default "AdobeID" value), with whom your email ID is registered with.
