6 Replies Latest reply: Sep 17, 2014 6:38 AM by Willam van Weelden RSS
    Adding Feedback
    Alchemex Community Member
      I am using Robohelp 10. What is the best way to add an option for the user to provide feedback from each topic? I would like it to send it via email from the web server that the helpfile is hosted on. How can I go about achieving this?
        • 1. Re: Adding Feedback
          Captiv8r CommunityMVP
          Hi there
          Just to confirm, this was posted in the HTML5 category. Are you using HTML5 or Responsive output from RoboHelp?
          Sorry to ask, but you would be surprised at the number of posts we see where folks aren't coming close to using the product for the forum being posted in.
          Cheers... Rick
          • 2. Re: Adding Feedback
            I'm using Robohelp 10 - Multiscreen_HTML5 output with a customized Screen Layout.
            • 3. Re: Adding Feedback
              Is it an option to add HTML code to the screen layout for a Feedback link to send an email and then use IIS to send the email?
              • 4. Re: Adding Feedback
                Willam van Weelden CommunityMVP
                The best option depends what you are trying to achieve. You can create a link that will create a new email in the user's default email program. That is the easiest way. For WebHelp there are several scripts available. For Multiscreen HTML5, the following will work:
                <script>
                var address = 'me@me.com';
                var url = document.location.toString();
                document.write('<a href="mailto:'+address+'?subject='+document.title+'&body='+url+'">Email</a>');
                </script>
                You can also use the IIS to send mail but that will require server side processing. You can either use a CGI script or a custom PHP/ASP script to do this for you. A script is not much work but it will need to be built by someone who can create server side scripts, such as a developer.
                Kind regards,
                Willam
                • 5. Re: Adding Feedback
                  Thanks William. I'd like IIS to send the mail which I can enable. I got an ASP script off a website (see below) but wasn't sure how to configure Robohelp to send to the server and it to process it. I'd like to add a Feedback link to the footer of the Screen Layout I have already created. We are trying not to involve developers due to costs.
                  sMailServer = "Email-Server-Name.mydomain.com"
                  sSendToEmail = "recipient-of-form@domain.com"
                  iMailServerPort = 25
                  sUsername = "user"
                  sPassword = "pass"
                  sBody = "Message from website:<br /><br />" & _
                    "Name:" & Request.Form("VisitorName") & "<br />" & _
                    "O/S:" & Request.Form("musictype2") & "<br />" & _
                    "Email Client:" & Request.Form("Email Client") & "<br />" & _
                    "Comment:" & Request.Form("VisitorComment") & "<br />"
                  sBaseConfigURL = "http://schemas.microsoft.com/cdo/configuration/"
                  cdoSendUsingMethod = sBaseConfigURL & "sendusing"
                      cdoSendUsingPort = 2
                      cdoSMTPServer = sBaseConfigURL & "smtpserver"
                      cdoSMTPServerPort = sBaseConfigURL & "smtpserverport"
                      cdoSMTPConnectionTimeout = sBaseConfigURL & "smtpconnectiontimeout"
                      cdoSMTPAuthenticate = sBaseConfigURL & "smtpauthenticate"
                      cdoBasic = 1
                      cdoSendUserName = sBaseConfigURL & "sendusername"
                      cdoSendPassword = sBaseConfigURL & "sendpassword"
                      Dim objMail: Set objMail = Server.CreateObject("CDO.Message")
                      Dim objConfig: Set objConfig = Server.CreateObject("CDO.Configuration")
                      Dim objConfigFields: Set objConfigFields = objConfig.Fields
                      With objConfigFields
                        .Item(cdoSendUsingMethod) = cdoSendUsingPort
                        .Item(cdoSMTPServer) = sMailServer
                        .Item(cdoSMTPServerPort) = iMailServerPort
                        .Item(cdoSMTPConnectionTimeout) = 10
                        .Item(cdoSMTPAuthenticate) = cdoBasic
                        .Item(cdoSendUserName) = sUsername
                        .Item(cdoSendPassword) = sPassword
                        .Update
                      End With
                      Set objMail.Configuration = objConfig
                      With objMail
                        .To = sSendToEmail
                        .From = sSendToEmail
                        .Subject = "Email from website"
                        .HTMLBody = sBody
                      End With
                      objMail.Send
                      Set objMail = Nothing
                      Set objConfigFields = Nothing
                      Set objConfig = Nothing
                  • 6. Re: Adding Feedback
                    In that case, you have to create a HTML form that you post to the ASP form on submit. You can create forms with RoboHelp, but it will also require a little manual HTML editing. See HTML Forms and Input for instructions on how to create forms.
                    One note: The name attribute of the form elements must be the same as the name your script is expecting, such as VisitorName and musictype2. I would advise against using names with spaces though.
                    Also, the ASP form may send email, but it would be best practice to show a message to the reader that their message has been send. The form you posted seems to send the message, but you will also need to show a thank you/message send page ortherwise the user will get an emtpy page when they send you the email.
                    Kind regards,
                    Willam
