Hi again Nancy
Please don't take this the wrong way, but from what you are
describing, I'm thinking you may not have a full understanding of
all the Captivate output files and what you may or may not need. So
for the first part of this reply, I'm going to do my best to
provide explanations.
You say you aren't seeing the two .SWF files mentioned in the
article, I'm guessing that you have opted to create a single .SWF
output from Captivate. This is done by clicking Project >
Skin... > Borders tab and DE-selecting the "Show Borders" check
box. The trade off with this approach is that if you have playback
controls enabled for your project, they move up and cover part of
your Captivate presentation.
You are seeing at least one .SWF file in your mix. This
should be your Captivate movie.
You also list the following files:
breeze-manifest.xml
_BDMetadata.xml
These files are normally produced when you click Project >
Preferences... > Preferences tab and have the option labeled
"Publish Adobe Connect Enterprise metadata" selected. I think this
option is selected by default and you need to turn it off if you
don't want those files. You wouldn't want those files if you aren't
using Adobe Connect (Formerly known as Breeze).
This leaves the final two files.
The file ending in .HTM and the standard.js file.
The .HTM file would only be used with RoboHelp if you were
linking the Captivate output as its own HTML page. If you are
directly inserting the Captivate .SWF inside an existing RoboHelp
topic. The standard.js is needed in order to display the content if
you are using the .HTM page that Captivate created. Again, this
isn't needed if you are directly inserting the Captivate content in
an existing RoboHelp topic.
So the looming question here that I see is to ask: Does the
Captivate play fine before you try to bring it into RoboHelp? If it
does, then an issue is being created by the manner in which you are
trying to get it into RoboHelp. If it doesn't, then you have an
issue with your Captivate output that needs to be addressed first.
From what you are describing, you are probably missing the
standard.js file. I'm further guessing that you simply gave up on
the article I pointed you to because you didn't see two different
.SWF files and you just assumed the rest wouldn't apply in your
situation.
Just in case it will help, here is the very brief skinny on
how to get Captivate into RoboHelp. There are two approaches. One
assumes you just want the Captivate movie in an existing topic. The
other assumes you just want to place the Captivate files in the
RoboHelp project and link to them.
For an existing topic, place your cursor where you want the
Captivate movie to be inserted. Click Insert > RoboDemo.
Navigate to where the .SWF file lives and select it. Badda bing
badda boom, it's inserted in the topic.
To bring the Captivate files in where you can link to them,
right click the folder where you want them inserted. Navigate to
the HTML page that Captivate created. The file with the .HTM
extension. Select it and it should import into RoboHelp. Add the
Standard.js file to baggage. Link to the page as desired.
Hopefully something here helps... Rick
