1. Re: Database access using windows authentication
Carl Von Stetten Sep 16, 2014 9:13 AM (in response to timeToPlay)ColdFusion does not pass user's credentials to the database connections by default, and cannot pass Windows Authentication credentials that way. It only sends the service account's credentials (if you leave username/password blank as you have done). The only way to pass user credentials is to put them into the individual query calls themselves, and even then you can't pass Windows Authentication credentials. You would have to use SQL Server Logins, and create accounts for each user.
I think most people are using either a dedicated SQL Server login for ColdFusion and run all queries under that account, or they do as you have already done and use Windows Authentication along with the ColdFusion service account. If you need an audit trail, then pass usernames into the insert/update queries and store them manually along with the other data you are inserting/updating.
-Carl V.
2. Re: Database access using windows authentication
timeToPlay Oct 21, 2014 6:56 AM (in response to Carl Von Stetten)Our Organization uses Kerberos to authenticate users against active directory for its .Net applications. I am trying to leverage this for use with CF and have set up the ColdFusion Sever's IIS to use the Kerberos authentication. Is there a way to have coldfusion calls to the database use the Kerberos authentication instead of the service account that the ColdFusion Server is running on? This would allow the database calls to use the windows login credentials instead of the service account credentials.
Thanks for any suggestions
Tim
3. Re: Database access using windows authentication
Carl Von Stetten Oct 21, 2014 8:41 AM (in response to timeToPlay)Not that I'm aware of. As far as I know, the only way to pass Windows authentication at all is through the ColdFusion service account. Otherwise, ColdFusion can only pass username/password via JDBC - which would utilize SQL Server authentication rather than Windows Authentication. The reason it works for .Net applications is that .Net natively supports Windows Authentication. ColdFusion does not.
-Carl V.
4. Re: Database access using windows authentication
timeToPlay Oct 21, 2014 9:44 AM (in response to Carl Von Stetten)Thanks Carl
Is there a java solution that CF could use. As I understand it, the .Net Apps also log in to the database with a service account but then use the impersonate feature granted to the account in Active Directory to use the windows login. Is there, perhaps a Java solution that coldfusion could use to enable impersonation?
Tim
5. Re: Database access using windows authentication
Carl Von Stetten Oct 21, 2014 10:14 AM (in response to timeToPlay)I haven't found one, but that doesn't mean one doesn't exist. I spent a couple minutes on Google, but nothing seemed to be on point.
Also, keep in mind that while IIS can use Kerberos authentication, once the request is passed to ColdFusion, IIS has nothing to do with how ColdFusion processes the server-side code or talks to databases.
-Carl V.
