1. Re: create Report charting data series
Eddie Lotter Sep 16, 2014 11:09 AM (in response to iccsi)I believe the following link will help you: http://helpx.adobe.com/coldfusion/kb/coldfusion-report-builder-charts-dynamic.html
2. Re: create Report charting data series
iccsi Sep 17, 2014 8:05 AM (in response to Eddie Lotter)Thanks for your information and help,
It works to use <cfquery>, but it gets error message when I change it to cfstoreproc.
<cfset ReportQuery.Q = getQ()>
<cfreport format = "PDF" template="MyTest.cfr" overwrite="Yes" />
<cffunction name="getQ" returntype="query">
<cfset var qq = ''>
<cfstoredproc procedure= "MyStoredProcedure" datasource="MySource"
<cfprocparam value = "#form.MyValue#" CFSQLTYPE = "cf_sql_date">
<cfprocresult name="mydata" resultset="1">
</cfstoredproc>
<cfreturn qq>
</cffunction>
Thanks again for helping,
Iccsi
Invalid token c found on line 76 at column 5.
The CFML compiler was processing:
- A cfstoredproc tag beginning on line 75, column 5.
3. Re: create Report charting data series
Eddie Lotter Sep 17, 2014 8:34 AM (in response to iccsi)<cfstoredproc procedure= "MyStoredProcedure" datasource="MySource"
You are missing a closing angle-bracket on this line, however it may be a typographical error in your post.
Change name="mydata" to name="qq" so that your function does not return an empty variable.
4. Re: create Report charting data series
iccsi Sep 17, 2014 9:09 AM (in response to Eddie Lotter)Thanks a million for the information and help,
The report runs, but it does not show the data from stored procedure which is from table from the query.
It looks like stored procedure did not execute.
I need pass 2 data sources to the report, one is for the tables on the report and one is for the chart.
Is it possible to pass 2 data sources to the report?
Iccsi,
5. Re: Re: create Report charting data series
Eddie Lotter Sep 17, 2014 9:15 AM (in response to iccsi)Is it possible to pass 2 data sources to the report?
Yes, that is why the chart's query is assigned to a request variable. The query that you pass to the report is the query parameter of the cfreport tag.
6. Re: Re: create Report charting data series
iccsi Sep 17, 2014 9:34 AM (in response to Eddie Lotter)Thanks a million for the information and help,
It seems that the chart query does not pass to the report for some reason.
The chart always show the data from the data from the query, not from stored procedure.
I save query as a variable, but it does not show the variable when I re open the report from report builder.
Are there any particular way to save the variable on the report for the chart?
Thanks again for the information and help,
Iccsi,
7. Re: Re: Re: create Report charting data series
Eddie Lotter Sep 17, 2014 9:43 AM (in response to iccsi)I just spotted another error in your CFML.
Change the following line
to
<cfset request.Q = getQ()>
The request.Q variable is the variable that you should have assigned to the chart as described in the link I posted earlier.
8. Re: Re: Re: create Report charting data series
iccsi Sep 17, 2014 9:53 AM (in response to Eddie Lotter)I have following code to generate the report.
mydata is source or report and getQ is the source of chart.
The report running and mydata correct on the report, but the chart does not get result from MyChartSP.
Do I have any thing wrong from the code following?
Thanks a million again for helping and information,
Iccsi,
<cfstoredproc procedure = "MySP" datasource = "MySource">
<cfprocparam value = "#form.MyValue#" CFSQLTYPE = "cf_sql_ineteger">
</cfstoredproc>
<cfset Request.Q = getQ()>
<cfset var qq = ''>
<cfstoredproc procedure= "MyChartSP" datasource="MySource">
<cfprocparam value = "#form.MyValue#" CFSQLTYPE = "cf_sql_integer">
<cfprocresult name="qq" resultset="1">
</cfstoredproc>
<cfreturn qq>
</cffunction>
<cfreport format = "PDF" template="MyReport.cfr" overwrite="Yes" query = "#mydata#">
</cfreport>
9. Re: Re: Re: Re: create Report charting data series
Eddie Lotter Sep 17, 2014 10:13 AM (in response to iccsi)For one thing, remove the number signs around mydata in the cfreport tag.
Let's make sure your chart's stored procedure is returning data. Try the following and see if you get the expected result set. My changes are in bold:
</cfstoredproc>
<cffunction name="getQ" returntype="query"><cfset var qq = ''>
</cfstoredproc>
<cfreturn qq>
</cffunction>
<cfset Request.Q = getQ()><!--- I moved this after the function definition just to be sure. --->
<cfdump var="#Request.Q#">
<cfabort>
<cfreport format = "PDF" template="MyReport.cfr" overwrite="Yes" query = "mydata">
</cfreport>
10. Re: Re: Re: Re: create Report charting data series
Eddie Lotter Sep 17, 2014 10:44 AM (in response to iccsi)Please forgive me, I never personally used the method documented in the link I provided. I have reviewed how I achieved the same thing and I did it differently.
Click on your chart in the Report Builder and in the Properties window give it a Name such as MyChart.
Then change your CFML to the following:
<cfstoredproc procedure = "MySP" datasource = "MySource"><cfprocparam value = "#form.MyValue#" CFSQLTYPE = "cf_sql_ineteger">
</cfstoredproc>
<cfprocresult name="MyChartData" resultset="1">
</cfstoredproc>
<cfreport format = "PDF" template="MyReport.cfr" overwrite="Yes" query = "mydata"><cfreportParam chart="MyChart" series="1" query="MyChartData">
</cfreport>
See the details in the ColdFusion documentation here:
11. Re: Re: Re: Re: create Report charting data series
iccsi Sep 17, 2014 10:56 AM (in response to Eddie Lotter)Thanks a million for the information and help,
It works now,
Does ColdFusion Report Chart support sub report?
I mean that I want to place the chart on the Group Footer and only shows all details record of this report.
Thanks a million again for help and information,
Iccsi,
12. Re: create Report charting data series
Eddie Lotter Sep 17, 2014 11:08 AM (in response to iccsi)It works now,
That's good to hear.
I have not done it myself, but the documentation says the name of the chart refers to a chart in a report or sub-report, so it seems that ColdFusion will find the chart as long as it is named correctly.
13. Re: Re: Re: Re: create Report charting data series
iccsi Sep 17, 2014 11:15 AM (in response to Eddie Lotter)Thanks a million again for helping and information,
Yes, according to ColdFusion Report document, it seems that it supports Sub Report and Sub Chart.
I will give it a try,
Thanks again for helping and information,
Iccsi,
