we are using IE 10, when we try to download the latest Flashplayer it seems to download ok but at the 68% mark when it tries to register it fails and give the error message - ERROR: Failed to Register. We removed the old version so now we have no way of getting a Flash file to run. What do we need to do to get the current version to run.
We are running on Windows 7
Hello,
Please provide the FlashInstall.log file located in C:\Windows\System32\Macromed\Flash. If you have a 64-bit OS, please also provide the file from C:\Windows\SysWow64\Macromed\Flash. The files may be fairly large so you can upload them following the directions here, How to share a document.
Maria
File attached
Philip Matticks
[private data removed]
You cannot attach files to email replies; you need to login to the forum and post the contents of the log file; or upload the file as described in https://forums.adobe.com/thread/1408375
You may also avoid posting your telephone numbers and email address in this public forum!
Original Poster provided this link in a new thread (which I deleted):
https://files.acrobat.com/a/preview/5acc89b3-ff55-42e5-907d-5e51d05fb2ba
Before running the reset_fp15.bat file can you run through these instructions and send the flashreport.txt report to ccampbel@adobe.com
Chris
Hi Chris,
From where can reset_fp15.bat be downloaded?
Thanks, Chris!
Could you also place that into https://forums.adobe.com/thread/987370
Hi Pat,
I updated the forum thread for Chris. We'll be sure to keep this updated in the future with each major version increment.
Maria
Hi Philip,
The install log file you posted was from the 32-bit location. Can you post the file from the 64-bit location (C:\Windows\System32\Macromed\Flash) as well?
Thank you.
Maria
