2 Replies Latest reply: Sep 18, 2014 6:57 AM by LisaM1960 RSS
    Open 2nd PDF from UNC-path fails
    LisaM1960
      Hallo,
      I use Adobe Reader 11.0.08 on Windows7 SP1 (Enterprise) and I try to open PDF-files from UNC-path. The first attempt is successful. If Adobe Reader is still opened, the attempt to open a 2nd PDF-file from (same or other) UNC-path in Windows Explorer does not work without any error message. The file does not open.
      The following attempts were successful or not:
      (drive P:\ = \\domain\dfs$)
      Double-click on \\domain\dfs$\path\file1.pdf opens the file.
      Double-click on \\domain\dfs$\path\file2.pdf does not open the file - no error message.
      Double-click on P:\path\file2.pdf opens the file.
      In Adobe Reader File - Open - \\domain\dfs$\path\file2.pdf opens the file too.
      Double-click on \\domain\dfs$\path\file2.pdf opens the file.
      Double-click on \\domain\dfs$\path\file1.pdf does not open the file - no error message.
      Double-click on P:\path\file1.pdf opens the file.
      In Adobe Reader File - Open - \\domain\dfs$\path\file1.pdf opens the file too.
      If Adobe Reader is still opened, but no file is opened:
      As you can see: If Adobe Reader is still opened, I can't open a PDF-file from UNC-path from Explorer. But that's what we need. Our Frontend-application opens an Explorer window and the user has to choose the PDF-files to open via double-click. It would be a very roundabout way to copy the Location from Explorer to open the file in Adobe Reader. We'd like to open the first and all other files for the same session from Explorer via double-click.
      Sure, if I disable protected mode every attempt works fine but unfortunatelly it is no permitted option to disable protected mode (security policy) - it has to be enabled.
      Each change in "ProtectedModeWhitelistConfig.txt" was not successful. For information its current config that works as mentioned above:
      ; Files Section
      FILES_ALLOW_ANY = \??\UNC\domain\dfs$\*
      (no entries in other sections)
      How can I open every PDF-file for a session from UNC-path via double-click from Explorer if Adobe Reader is still opened ?
      Thanks in advance for any help.
      Lisa
