I have a MacBook Pro running Macintosh OS 10.9.4.
I am using Java version 1.6.0_65
I just ran the Developer installer for Coldfusion 11.
I started the service using sudo ./coldfusion start and saw the following messages:
Starting ColdFusion 11 server ...
The ColdFusion 11 server is starting up and will be available shortly.
ColdFusion 11 server has been started.
ColdFusion 11 will write logs to /Applications/CF11/cfusion/bin/../logs/coldfusion-out.log
When I tried to navigate to 127.0.0.1:8501/CFIDE/administrator/index.cfm the page loads blank.
I checked the error log and it gives me a long list of problems starting with a complaint about
The APR based Apache Tomcat Native library:
Sep 11, 2014 4:04:10 PM org.apache.catalina.core.AprLifecycleListener init
INFO: The APR based Apache Tomcat Native library which allows optimal performance in production environments was not found on the java.library.path: /Users/ericrose/Library/Java/Extensions:/Library/Java/Extensions:/Network/Library/Java/Extensions:/System/Library/Java/Extensions:/usr/lib/java:.
Sep 11, 2014 4:04:11 PM org.apache.coyote.AbstractProtocol init
INFO: Initializing ProtocolHandler ["http-bio-8501"]
INFO: Initializing ProtocolHandler ["ajp-bio-8014"]
Sep 11, 2014 4:04:11 PM org.apache.catalina.core.StandardService startInternal
INFO: Starting service Catalina
Sep 11, 2014 4:04:11 PM org.apache.catalina.core.StandardEngine startInternal
INFO: Starting Servlet Engine: Apache Tomcat/7.0.52
java.lang.ExceptionInInitializerError
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:57)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
at java.lang.reflect.Constructor.newInstance(Constructor.java:526)
at java.lang.Class.newInstance(Class.java:374)
at coldfusion.bootstrap.ClassloaderHelper.initFilterClass(ClassloaderHelper.java:150)
at coldfusion.bootstrap.BootstrapFilter.init(BootstrapFilter.java:34)
at org.apache.catalina.core.ApplicationFilterConfig.initFilter(ApplicationFilterConfig.java:279)
at org.apache.catalina.core.ApplicationFilterConfig.getFilter(ApplicationFilterConfig.java:260)
at org.apache.catalina.core.ApplicationFilterConfig.<init>(ApplicationFilterConfig.java:105)
at org.apache.catalina.core.StandardContext.filterStart(StandardContext.java:4809)
at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5477)
at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:150)
at org.apache.catalina.core.ContainerBase$StartChild.call(ContainerBase.java:1559)
at org.apache.catalina.core.ContainerBase$StartChild.call(ContainerBase.java:1549)
at java.util.concurrent.FutureTask.run(FutureTask.java:262)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
at java.lang.Thread.run(Thread.java:745)
Caused by: org.apache.commons.logging.LogConfigurationException: org.apache.commons.logging.LogConfigurationException: No suitable Log constructor [Ljava.lang.Class;@7e02856c for org.apache.commons.logging.impl.Log4JLogger (Caused by java.lang.NoClassDefFoundError: org/apache/log4j/Category) (Caused by org.apache.commons.logging.LogConfigurationException: No suitable Log constructor [Ljava.lang.Class;@7e02856c for org.apache.commons.logging.impl.Log4JLogger (Caused by java.lang.NoClassDefFoundError: org/apache/log4j/Category))
at org.apache.commons.logging.impl.LogFactoryImpl.newInstance(LogFactoryImpl.java:543)
at org.apache.commons.logging.impl.LogFactoryImpl.getInstance(LogFactoryImpl.java:235)
at org.apache.commons.logging.impl.LogFactoryImpl.getInstance(LogFactoryImpl.java:209)
at org.apache.commons.logging.LogFactory.getLog(LogFactory.java:351)
at coldfusion.portlet.wsrp.ProviderImpl.<clinit>(ProviderImpl.java:72)
... 19 more
Caused by: org.apache.commons.logging.LogConfigurationException: No suitable Log constructor [Ljava.lang.Class;@7e02856c for org.apache.commons.logging.impl.Log4JLogger (Caused by java.lang.NoClassDefFoundError: org/apache/log4j/Category)
at org.apache.commons.logging.impl.LogFactoryImpl.getLogConstructor(LogFactoryImpl.java:413)
at org.apache.commons.logging.impl.LogFactoryImpl.newInstance(LogFactoryImpl.java:529)
... 23 more
Caused by: java.lang.NoClassDefFoundError: org/apache/log4j/Category
at java.lang.Class.getDeclaredConstructors0(Native Method)
at java.lang.Class.privateGetDeclaredConstructors(Class.java:2493)
at java.lang.Class.getConstructor0(Class.java:2803)
at java.lang.Class.getConstructor(Class.java:1718)
at org.apache.commons.logging.impl.LogFactoryImpl.getLogConstructor(LogFactoryImpl.java:410)
... 24 more
Caused by: java.lang.ClassNotFoundException: org.apache.log4j.Category
at java.net.URLClassLoader$1.run(URLClassLoader.java:366)
at java.net.URLClassLoader$1.run(URLClassLoader.java:355)
at java.security.AccessController.doPrivileged(Native Method)
at java.net.URLClassLoader.findClass(URLClassLoader.java:354)
at java.lang.ClassLoader.loadClass(ClassLoader.java:425)
at java.lang.ClassLoader.loadClass(ClassLoader.java:358)
... 29 more
Sep 11, 2014 4:04:12 PM org.apache.catalina.core.ApplicationContext log
INFO: failed to load: coldfusion.portlet.wsrp.ProviderImpl
Does anyone know how to solve this problem?
erose68,
Can you please try using the default java with CF11, and see if you run in to the same problem.
You can edit the jvm.config file at <cf_root>/cfusion/bin and point the java.home setting to the default location at <cf_root>/cfusion/jre.... . Pls. back up the original file before making any changes.
What do you mean "the Default Java"? Version I am using Java version 1.6.0_65 is the one which was installed on the Mac when I got it from the store.
The jvm.config file contains the following line:
java.home=../../jre/Contents/Home/jre
- this is already pointing at the directory you described in your email, isn't it?
CF11 packages its own JRE. It is physically located in the path your java.home in jvm.config seems to be pointing to. So, it should not matter if you have any other Java installed in your OS.
You can, though, manipulate that jvm.home setting to make it point to a "non CF" JRE, so that your CF uses an external JRE.
BTW, CF11 ships with (Java 1.7u51, later changed to Java 1.7u55). In all likelihood, it will not work with the older JDK1.6.
Can you check if files at ".<cf-root>/jre/Contents/Home/jre" are physically present
If you continue to face the issue, can you please reach out to cfinstal@adobe.com for help.
